Tip & How-To about Cell Phones
SAMSUNG TIPS
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
Cell Phones Logo
default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
Aug 10, 2011 | Computers & Internet
I NEED CODES SECRET
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
Nov 28, 2010 | Samsung S3653 Cell Phone
secret codes of samsung?
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung mobiles
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#
Aug 12, 2010 | Samsung SGH-D900 Cellular Phone
KEY CODES FOR SAMSUNG YP-T9JB
Samsung Secret Codes Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: ...
Jul 12, 2009 | Samsung Yepp YP-T9 Digital Media Player
377 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
