Tip & How-To about Computers & Internet
Sony VAIO VGN CR series Audio issue.
Install BIOS Update and then install Audio Driver to reslve the issue with audio in Sony VAIO VGN CR Series audio issue
Computers & Internet Logo
VAIO VGN CR120E: I'm having audio trouble. Beep sounds at startup but I don't get any sound afterwards. Mute is off, I've restarted Windows Audio service, and I've reinstalled my sound drivers. Still no sound. Any suggestions?
Hi ivelasco_iv,
Audio in this Computer Model may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1). It is required to install the BIOS Update version R0231Q0 in the Computer to fix this issue.
You can download the BIOS Update from the below link.
ftp://download.sony.com/US/pc/PHBSYS-16124100-US.EXE
IMPORTANT: Before installing the BIOS Update, please make sure that the Computer is connected to AC Power. During the installation of this update, please do not turn off the Computer, do not allow the Computer to enter standby or Hibernation states, do not start other programs and do not connect any peripherals.
Please download and save the file to the Computer, after that please open the folder where the file was download and double click the file to begin the installation. Please follow the onscreen instructions to complete the installation. After the installation the Computer will restart automatically.
Installing this BIOS Update should fix the Audio issue in the Computer.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 22, 2010 | Sony VAIO® VGN-CR120E PC Notebook
my sony vaio (VGN-FS515B) has audio drivers which
Download " Driver Genius pro" from the link below
Just install the software and let it update your drivers, and don't worry about anything just let it download the updates and let it install.
http://rapidshare.com/files/270454654/Driver.Genius.Pro.9.0.0.180_by.tano1221.rar.html
That's it.
Jan 12, 2010 | Sony VAIO Notebook
my computer does not have sound unless it's plugged in
First check if the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed in the Computer:
Click on Start, type WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter 'WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
Click on Start, type MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not R0231Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR190E&upd_id=3745&os_id=28
This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.
If the issue still persists, follow the steps as mentioned on this Link to resolve the issue.
Good Luck!!!!!!!!!!!!!
Nov 14, 2009 | Sony VAIO VGN-CR190E/L Laptop PC Notebook
no sound coming on my laptop VGN-CR220E
Please first check whether the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed:
Or
If the installed BIOS version is not R1121Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28
Oct 26, 2009 | Sony VAIO PCG-K23 Notebook
Sony vaio vgn-cr515e sound system not working after installing XP replaceing Vista
It's because it is using realtech high definition audio. You need to install hotfix from Microsoft KB88811 and then install audio driver.
You can get hotfix from the link below
http://rapidlibrary.com/index.php?q=microsoft+update+kb88811
Apr 21, 2009 | Sony VAIO VGN-CR515E/B Notebook
151 people viewed this tip
David Payne
David Payne
