Tip & How-To about Cell Phones
If your Cordless battery drains
There are many instances of battery draining but most of the time it is due to poor quality of battery including those that are in shelves which have lost the charge capacity.So here are some tips
Unless the phone is showing any malfunction we cannot confirm unless a drain test is taken in the standby condition of the phone.This must be quite negligible current about few mAmps . If there drains is more check for leak in the battery source to the IC feed, a possible zener shorting or a capacitor leaking.
However if the phone is using up power on talk time , it can be due to drain in a functioning circuit which will be hard to find , but check for unusual heating in any components.
If there was leak in the board this must be ccleaned out well with petrol and may be insulated with varnish.
If however the phone works fine then it can be the fault of the battery itself as it could have developed reverse polarity.
Let the battery drain off fully and recharge, if possible a jump charging with an external voltage might sometimes cure this issue.
If not change the battery with the correct current rating.
Cell Phones Logo
Roland street cube won't power on due to battery acid leak
Most likely the acid ate the internal power supply, but if you can dis-assemble it and clean any trace of gunk with a toothbrush and electronic cleaner, including the fuse and it's contacts, maybe you'll get lucky.
Nov 07, 2014 | Roland CUBE Street Amp Combo
where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
overheating L7
It can be due to the battery getting warm while the phone is used continuously or when the charger is connected for charging the battery. It is possible that a poor battery can heat up when the current is drained.
If the phone by itselt is heating it can also be due to shunting due to poor signal strength or connectivity as the phone HUNTS for the signal therby working with a higher output.
Nov 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal
Jul 04, 2009 | Yahoo Messenger
Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Dec 27, 2007 | HP LaserJet 4500 Printer
147 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
