Home | All Products | Duet GHW9150P Front Load Washer | Tips
F02 Error Code on Whirlpool Duet & Kenmore Elite Front Loaders
jsrock516
By Guru jsrock516
Rank: Guru
Rating: 96%, 6704 votes
posted on May 22, 2008
Very Helpful
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Was this helpful?
Yes
No
37 people thought this was helpful
Comment #1
posted on Sep 21, 2009
TRISH FR FLA
By Apprentice TRISH FR FLA
Rank: Apprentice
Rating: 0%, 0 votes
Guru...like my daughter would say "YOU ROCK"! Well, I did what you said and I found a hair tie clogging the pipe and quarters in the trap. Thanks for the great advice..you saved me $50 and the wait for my home warranty repair person.
Comment #2
posted on Aug 18, 2009
tonyankristy
By Apprentice tonyankristy
Rank: Apprentice
Rating: 0%, 0 votes
Just finished up the instructions you have posted. Thank you very much for saving me the time and money for a service call. Very easy to do and I found a "rotten sock" in the filter. Now the mildew odor is gone and machine does not have the SUDS problem like before.
Comment #3
posted on Aug 14, 2009
SuzeQ58
By Apprentice SuzeQ58
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do what the instructions said but we couldn't get 00 so we did the drain/spin option. tub didn't drain. so we started from step one to clean out pump basket & then we attached the wet/dry vac to the discharge hose and you could feel some kind obstruction release...I'm pretty sure the obstruction was the rubber backing from area rugs that after awhile dries out & gets brittle and when wet.....falls apart in the washer & can plug everything up.
so advice to all you people out there.....when an area rugs rubber backing becomes dried out...its cheaper to replace the rug then have to replace parts on a washer.
Its great knowing that this website is here & experts like jsrock516 is willing to share his knowledge to help other people out...
Thanx JSROCK516 !!!!
Comment #4
posted on Aug 08, 2009
smp3214
By Apprentice smp3214
Rank: Apprentice
Rating: 0%, 0 votes
JS you Rock !
I'm the guy that would have taken the drain plug off and had a gallon of water on his hardwood floors.
So after removing the water, I took the plug off and found a nickel, penny, and a pen cap that must have been stuck in the impeller of the pump. The cast iron rod for the impeller snapped. I'm assuming from the pen cap getting stuck.
So I'm off to get a new pump. Thanks for saving me the call to the  Repair man.
You Rock!
Can you Help with these Washing Machines problems?
Whirlpool Duet GHW9150P Front Load Washer
door bellow keeps coming off
wash cycle stops with a sud code followed by f35
Cannot open washer door.
I have a problem with my washer....I was doing a wash load...
during the spin it is has a loud humm and wont spin. It...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
