Tip & How-To about Video Game Consoles & Games
How to get the move swap code
How to you manage to get the swap move in ssbm?
Video Game Consoles & Games Logo
My washing machine washes and then it won't drain. I tried moving it to another cycle to see if it still worked and no cycles work. And it still won't drain
Try setting it to a drain and spin cycle, may need doing repeatedly. I managed doing this for a couple of years but machine did eventually die. Once drained check that all filters are clear. Just reread your question, and wondered if you had checked the fuse in the plug, swap for the same rated fuse and try again. Hope this helps
Jun 08, 2017 | Washing Machines
how to fix code P0306 cylinder 6 misfire?
Swap spark plug with cylinder 4. Swap COP (coil over plug) with cylinder 2.
If problem moves to cyl 4, bad spark plug.
If problem moves to cyl 2, bad COP.
If problem remains in cyl 6, suspect valve or piston problem.
Start with compression check
Aug 27, 2014 | 1999 Ford Crown Victoria
How do I have moved office and have connected my phone (panasonic kx-dt346) but I do not have an extension number, how do I program on in for my phone line? as no one can call me, but I can call out?
You have one, press the INFO button up to 3 times and your extension number will show on the display. A 6-line display phone is pretty unusual to be moving from one place to another as it's the control phone. If it was the only one in your system, MOVE IT BACK.
There is a manager's guide in the Operating Manual for your system that will give the instructions for changing extension numbers. It starts by going into manager programming (PROG **1234) and choosing program 004. In Panasonic land, you don't "swap" extenson numbers, you do a double change as in change 102 to 200 105 to 102 and 200 to 102.
Carl
Jul 04, 2011 | Panasonic KXDT346 Phone
I'm trying to play Final Fantasy Crystal Chronicles on my Wii. It's a GameCube game. However, after i select "Start" on the Wii disc menu, the disc stops spinning and the entire system resets. We tried another GameCube game, Super Smash Brothers Melee, but did not have the same issue. The FFCC disc is MUCH cleaner than SSBM, the system is updated and will play any Wii game we tried.
maybe it has to do with scratches deep scratches that won't come out sometimes it only takes 1 sometimes it takes 10 its all chance and a good way to find out is some disc fixer if it can't get it out its a bad scratch (and disc fixer never seems to run out i got $7 gamestop one years ago i still use)
Jan 16, 2011 | Nintendo Video Game Consoles & Games
how can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
931 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
