Tip & How-To about Electrical Supplies
Generator Not Producing Power ? Stator Winding
There are 4 requirements that have to be met before a generator is able to produce power. Due to number of questions that have been asked, a Coleman PowerMate 1500-1850 with a Briggs and Stratton Engine will be used here.
1) The Engine has to be turning at correct speed
2) Field Winding (Rotor) on the alternator must be energized
3) AC Winding (Stator) must create a voltage in presence of magnetic field
4) Output passes through Safety Devices before it reaches an outlet.
This Tip will cover the Stator Winding.
The stator winding is the winding that is around the outside of the rotor. It doesn't usually move. Previously, the alternator design was called a revolving armature, in which the field was stationary (outside), and the stator (armature) was the rotating member. This quickly was replaced, eventually, by the revolvingfield configuration, since the brushes carry a relatively small DCcurrent, rather than a larger AC current with destructive arcing. Brushes were prone to failure due to high wear.
In the revolving field architecture,there are primarily 3 types of alternators: Single Output, MultiOutput, and MultiPhase.
The single output alternator is just that, it outputs a single voltage. Typically, it will be either120vac (60Hz), or a single phase 240vac (50Hz) depending on the country it was bought in. The stator winding of this kind of alternator has only a single winding, with 2 wires coming off of it. One of these wires goes to the neutral bus for the outlets, the other wire goes to the circuit breaker, and the other side of the circuit breaker goes to the outlet. Disconnect both of the wires, and use your multimeter to check the continuity between them. You should have continuity here. Also check each wire to the frame of the alternator, there should not be continuity here though. If you don't have continuity between the wires, or if you have continuity between the wire and alternator frame, then you have what is called a grounded winding. This will have to be addressed by a motor shop, or replace the stator in its entirety. It is generally more cost effective to replace the generator though. Remove and sell the copper wire, and use that money towards a replacement generator.
Multiple Output alternators are usually found in the next step up from "bargain" generators. These usually will have an output of 120/240vac, and likely a low voltage battery charging circuit as well (12vdc being most common). The stator for these is checked in the same way as a single output, with a caution on the low voltage winding. On the low voltage winding,there will be a single diode (called half wave rectification) or a full wave rectifier (2 diodes) connected to the windings. You must disconnect at least 1 wire from the diodes to check the windings, and both wires to check for continuity between the windings and the frame of the alternator. If you don't disconnect the wire(s), the 1 way nature of the diode will indicate no continuity when there should be,and may cause you to not see continuity when there actually is (to the frame).
If the low voltage winding is open, the generator is still usable for the 120/240vac features. You just won't have benefit of the low voltage battery charging circuit, which is actually a very poor charger to begin with.
On a 120/240vac alternator, there may also be a switch that turns the 240vac on and off at the receptacle. This switch is put here so that the 2 120vac windings can be put in parallel for greater current capacity if 240vac is not required. If you have 120vac, but not 240vac, and the circuit breakers are not tripped, this switch is likely the culprit. It is just a double pole double throw switch that is easily replaced with one of the same type, and same or higher current rating. Never switch from 120 to120/240vac or vice versa while the engine is running. To do so invites winding damage due to arc-over, and may damage any devices that are connected from the voltage spike.
MultiPhase alternators are nothing more than single output alternators with a twist. Rather than having a single winding, there will be 3 windings, with a 120 degree phase separation. The in phase neutral wires will all be tied together, but the phase outputs will be separated, and connected to the receptacle in a specific order. This is called a Wye (Y) configuration. An alternate configuration is when the windings are all connected to each other, end to end style. The junction of each connection is then brought out to the receptacle. This is called a Delta configuration. Three phase / multiphase alternators will not be discussed in depth here as a much higher technical knowledge will be required.
As far as the stator winding goes, that is it. If you have continuity where you should, and don't have continuity where you shouldn't, the stator winding is likely good. As mentioned, if the low voltage battery charge winding is open, but not grounded / shorted to the frame, the primary function of the alternator is still usable.
If your checks of the stator are good,time to move on to the next tip.
Output and Safety Devices
Electrical Supplies Logo
power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Sep 01, 2009 | Coleman Powermate Premium Plus 6250W...
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
I have a coleman 5000 that runs fine but it stops producing power after it runs for a couple of minutes.
Same answer as the last time you asked, likely a flying open. If the rotor test proves that your rotor isn't opening up, test the capacitor on brushless models or the voltage regulator board on brush generators.
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
5,035 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
