Tip & How-To about Cameras
Installing Your Digital Camera Driver On Your Windows Computer
Installing Your Digital Camera Driver on Your Windows Computer To transfer digital camera photos to your computer, you need to install the camera's driveron your computer. You can install a driver fairly easily on a Windowscomputer, and that driver lets you access your digital camera photos onyour computer. To install the driver:
Enlarge1Choose Start→Control Panel→Printers and Other Hardware→Scanners and Cameras→Add an Imaging Device.The Scanner and Camera Installation Wizard opens with the Welcome screen, as shown in this figure.
Enlarge2Connect your camera or card reader to your computer (placing your camera in Connect mode, if necessary). You can probably connect your camera by using a USB cable, as this figure shows.
Enlarge3Select Automatic Port Detection in the wizard (see figure), then click Next.The Camera Selection window opens.
Enlarge4Select your digital camera make and model in the Camera Manufacturer and Model lists; then click Next.If your camera or card reader isn't listed,install the driver from the disk that came with your device. Place thedisk in the appropriate drive and click the Have Disk button. Thewizard walks you through the process.
5Turn your connected camera on. Click Next.The Installation Wizard now asks you to name your device.
Enlarge6Type a name for your camera or device. Click Next.Choose a name that makes sense to you, or the camera's make and model.
7To complete the Windows installation process, click Finished.
Cameras Logo
how do I transfer my photos from camera to computer - out of town with no manual
First of all computer need compatible camera driver/software to communicate with your device (camera), you can download camera driver from its manufacturer's (camera) website. After installing camera software/driver into your PC (Computer). Connect your camera with computer through USB Cable that came up with the camera and transfer photos.
Thanks...!!
Nov 18, 2010 | GE X5 Digital Camera
Upgraded to Windows 7 & it no longer recognises my Pentax Optio S5i camera ? Cannot download my photos since installing Windows 7. Can we get updated software for my camera ?
HI there there try to download the windows 7 camera driver from pentax website. It will start work then. Another way is remove the memory card & put in in a card reader then you can also transfer all photos from card to computer For further help ask me . Thanks.
Mar 23, 2010 | Pentax Optio S5i Digital Camera
cannot transfer photos from kodak computer to
With Windows XP it is possible to connect the camera and transfer pictures without using the Kodak drivers as contained in EasyShare software. Windows XP contains built-in drivers (Windows Imaging Acquisition or WIA drivers) that will recognize your digital camera.
It is a good temporary alternative to using EasyShare if there are issues with installing the software, as it will at least enable you to transfer pictures to your computer. You will however lose the ability to upload any files or information to the camera, such as:
-firmware updates
-e-mail address books
-the Camera Favorites album which is a feature of some of our newest cameras
Simply connect your camera and use the Device Manager to configure Windows on how to work with the camera:
-Right-click on My Computer and choose "Manage". Click [Device Manager] in the left pane.
-Click the plus (+) sign in front of "Imaging devices". The camera should be listed below it.
-Right-click on the camera and select "Update Driver".
-If you have installed Windows XP Service Pack 2, you will be prompted, "Can Windows connect to Windows Update to search for software?" Select "No, not this time". Click [Next].
-Select "Install from a list or specific location (Advanced)" and click [Next].
-Select "Don't search. I will choose the driver to install". Click [Next].
-Select "Digital Still Camera". Click [Next].
-Check that a program selection window appears. Select "Always use this program for this action".
Now your camera should be accessible via My Computer under "Scanners and Cameras".
Oct 25, 2009 | Kodak Cameras
Software and Driver Needed...
Can you provide your camera make/model to offer you a link to download your drivers. Thank you.
You could use a card reader connected to your computer and this would not require any drivers.
Dec 06, 2007 | Cameras
driver update problem for digital camera
Forget the hassle of trying to get the camera linked to the pc with software etc....
Much faster transfer of photos and no hassles with a usb card reader works every time 'no drivers' to mess with.....
http://www.memorybits.co.uk/shop/card-readers/14-in-1-card-reader-plus-100-meter-bluetooth-dongle-/4314
Nov 21, 2007 | Canon PowerShot A400 Digital Camera
308 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
