Tip & How-To about Office Equipment & Supplies
Toshiba estudio 162 e-studio 162 L1 L1-00 Error Code
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
we have a red light on pointing to the middle of the copier with a ! mark. it says the it is a error # L1-00
Good Luck and Thank You for using Fixya.
Feb 04, 2011 | Sharp AL 1631 Copier
error l100
Jan 12, 2011 | Sharp AL-1651CS All-In-One Laser Printer
my scaner is flashing L1
WheatlandServices
Dec 19, 2010 | Toshiba e-Studio120 Copier
sharp 1642, erro L1
Oct 16, 2010 | Sharp AL-1641CS Laser Digital Copier
What does a flashing code L1 mean
Sep 27, 2010 | Sharp AL-1457 Black and White Copier
2,213 people viewed this tip
jasbo
jasbo
