Tip & How-To about Toshiba 50H81 50" Rear Projection Television
What to do when you only have Green on a CRT Projection TV.
If you have a picture, but only in green on a 3 crt projection TV, I would try turning up the drive for the red and blue guns. They have probably changed over time and red and blue have lost drive and need a boost. Green makes up 70 percent of the picture compared to red and blue so the drive would not have to drop much to lose red and green but still have green. Keep in mind that this does mean that the CRTs are dying and may not have too much time left.
To turn up the drives first remove the back cover on the bottom half of the machine. Be very careful as you will have to work on this unit live. Do not touch anything other than what I tell you and keep one hand in your pocket whenever possible.
First look at the space above the main circuit board. Somewhere across the beam supporting the CRTs you will see a square box with 6 controls (shafts). You can locate the box if you follow the wires from the flyback to the box. The flyback is located on the power board and produces the high voltage. It will have 4 large red rubber wires coming out of it. Three go to the focus divider block (the box in question) then they go on to the crts (red, green, blue).
Once you locate the focus divider look at it closely. The focus controls are on top and the drives are on the bottom. They should be marked red, green and blue. You want to turn up the red and blue. Tune a picture with as much black as possible. While watching it turn up the red until you see a red tint or streak then turn down until it just disappears. Do the same with the blue. You may want to touch up the green also for good color balance.
If the set is working OK and the CRTs have enough drive left, your picture should look normal.
Thanks for using FixYa.
hardrocko
Toshiba 50H81 50" Rear Projection Television Logo
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
color is bad especially colors like orange and the white on peoples teeth is black most of the time andthe picture is not clear
HI, thank you for visit fixya.
Common problem on this set .
Picture tube liquid is dirty.
Mostly in crt green and crt blue.
Do you have electronics skills?. If so, open the TV ( back cover), you will see green,blue and red gun. After turn on your tv, select any channel or video signal, cover with piece a paper two guns at the top ( any), and see how look the picture in the front, try one at time, ( press menu on remote control and see leters-clear). I am sure the green and blue will be no clear. all the time red tube is fine.
REPLACE COOLANT LIQUID PROJECTION ( solution).
I will be here for any quetions.
Thank you
Dec 01, 2009 | Philips 60PP9352 60" Rear Projection...
green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
2,065 people viewed this tip
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
