Tip & How-To about Heating & Cooling
Air Conditioning Tips
Please let the information below, remind you to stay cool and keep your A/C running at peak performance.
The following is information you should know and use to help assure that your Air-conditioning is keeping you as cool as possible and working and cooling as efficiently as possible, saving you money. The following should help you decide if you need a professional to service your Air-conditioning unit.
(1) Air filter(s) MUST be clean. They should be located near the return air duct adjacent to the air handler or in a return air grill(s). Check your air filter every 30 to 90 days to make sure it is clean. Depending of the house, i.e. if you have animals you may need to clean the air filter more often. (Go clean them now!)
(2) Flip the switch on the thermostat for the fan setting to FAN ON, not AUTO. This will run the indoor fan nonstop. The outside A/C unit will still cycle with a call for cooling from the thermostat. The constant air moving will keep you cooler. You can probably keep the thermostat a degree or two higher than normal and still feel comfortable. You will also maintain a more even temperature between upstairs and downstairs. This will SAVE you MONEY because the outdoor condenser will not come on as much!
(3) Make sure that you wash the outside condenser coil once a year. If it's dirty, the A/C will run hot and inefficient. A sign of the coil being dirty is the small exposed copper (pipe) (tubing) line, usually 3/8" O/D connecting the inside unit with the outside unit will be HOT to the touch.
(4) If the small exposed 3/8" copper pipe connecting the inside unit with the outside unit is hot to the touch there can be several reasons why;
(a) A/C is low on refrigerant.
(b) The outdoor condenser coil is dirty. Those are the two most common reasons for it to be hot to the touch.
(5) "Warm Rooms" on the lower levels of the house where it is cooler cut back or cut off some vent registers (Diffuser) and make sure that all the ones on the upper floors where it is warmer are open all the way! Also, see paragraphs #2 & #9.
(6) "Doors" if you close the door to a room make sure that there is about a 3/4" gap between the bottom of the door and the floor. You may have had carpet put down on the floor and now there is no gap. This is necessary if you have a central return air duct in the hallway. The return air ducts need to pull the warm air from the room.
(7) Never leave the house and turn OFF the A/C. then come back home and turn it on and expect it to cool the house anytime soon. Doing this will not allow the unit to cool down the house for several hours. You can set the temperature up five to ten degrees but NOT OFF. This is because of Latent heat buildup in the walls and furniture in the house and will make the A/C work harder to remove the heat, this takes a long time.
(8) Never turn the A/C off than back on in less than five minutes, this will short-cycle the compressor and can trip breakers, blow fuses, or cause permanent damage the compressor. You should have a time-delay install on the A/C to prevent this during power outages! Some setback thermostats have a time-delay built-in. Having a start capacitor and relay is a good idea. This will increase the life expectancy of the compressor by starting faster thus keeping motor temperature down, using less electric to start.
(9) Keep blinds closed, curtains drawn, window shades drawn, a working attic fan would be a good idea, plenty of insulation in the ceiling & walls, air tight storm windows, keep outside doors and openings close, etc.
(10) "Icing of the indoor coil or the large insulated covered copper pipe "There are two main reasons for this, lack of air flow or low on refrigerant. Lack of air flow can be a dirty air filter, dirty indoor evaporator coil, dirty fan blades, damper in duct restricting air flow.
(11) "Water inside around air-handler" see paragraph 10. The condensate line is a drain pipe coming from the indoor evaporator coil to a indoor drain or to the outside. This can become clogged and cause water to backup and can produce about five gallons of water an hour. This is where all the humidity and moisture from the house goes.
(12) You should NEVER need to add refrigerant to a system, if you are adding refrigerant this means that there is a refrigerant leak in the system that SHOULD be fixed! "Why KILL the Ozone layer?"
(13) Checking the cooling with a thermometer. There should be a 15-20 degree temperature drop across the indoor coil at the air handler. Check the temperature drop in the duct close to the coil, if air coming into the coil is 75 degrees than the air leaving the coil should be 60-55 degrees. If it is higher or lower there is probably something wrong. Too high of a drop, IE more than 20 degrees drop, could mean lack of air flow or low on refrigerant. Less than a 15-degree drop could mean too much air flow, dirty outside coil or low on refrigerant.
(14) Never cover the A/C with plastic or an air tight cover; this will cause it to rust.
(15) Do NOT let animals (Cats) (Dogs) etc. Urinate on the outside coil. This will cause it to corrode (rust) and then leak refrigerant.
(16) Keep grass & weeds from blocking air flow on outside A/C.
(17) Do NOT build a deck close to the top of the outside A/C or anything else that could cause the warm discharge air to re-circulate back to the unit.
(18) Fuses, Circuit Breakers or wires should never be hot to the touch; if they are hot you may have a sizing problem or a loose or bad electrical connection.
(19) You can stop hear, the rest may not interest you.
When you need to have your equipment repaired/serviced make sure you use a licensed contractor who should be insured and obtain permits from city/county officials when required/necessary. Or a member of the (PHCC) Plumbing, Heating, Cooling Contractors Association. PHCC contractors are professionals who adhere to a published code of ethics that improves the industry and protects your health, certified by the State Board of Contractors. They also have licenses, bonds, insurance and obtain permits when required by local municipalities. The PHCC logo is your assurance of quality in this profession! Isn't your health & safety worth it? It should be! Call 1-800-533-7694 for more information about the PHCC.
Air-Conditioners DO NOT add cool air. What they do is remove warm air and put it outside. R-22 & R-12 ETC.. Refrigerant is a manmade product invented by DuPont and given the trade name FREON.
Heating & Cooling Logo
Why does it run roughly at 190 degree engine temp?
Hi, Bob in order for you engine to run at peak performance and maximum efficiency it needs to achieve an operating temperature of 180-230 degrees Fahrenheit, this temperature is also necessary to evaporate any water that may accumulate in your oil system due to condensation, if you check your oil and it has a milky color it's contaminated with water and should be changed ASAP to prevent engine damage. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief $6 a month
Mar 12, 2016 | 2006 Harley Davidson FLHX Street Glide
i just found out we have an enviracaire elite system in the attic which was switched off. how do we clean it? does it have a removable filter? Model: 2084175 120 vacd 60HZ dim: 18 x 25 -- thanks -- Irene
CLEANING PREFILTER(S), CELL(S) AND POSTFILTER(S) CAUTION Sharp edges. Can cause personal injury. Carefully handle cell(s) or wear protective gloves to avoid cuts from sharp metal edges. Setting a regular cleaning schedule To ensure optimum performance from the air cleaner, the prefilter(s) and cell(s) must be cleaned regularly- twice a year with normal use or more frequently with heavy use. Use the wash reminder schedule below to help establish and maintain a regular cleaning schedule. Mount the wash reminder schedule in a convenient location. NOTE: You may let the heating or air conditioning system operate normally while the cell(s) are being washed. Simply turn off the air cleaner switch. Cleaning your Prefilter 1. The quickest and easiest way to clean your prefilter is to use the brush attachment of your vacuum cleaner to vacuum the lint off the dirty side of the prefilter. Greasy dirt may require soaking the prefilter in a tub or rinsing with the garden hose. Do not wash the prefilter in the dishwasher or car wash 2. The prefilter should be cleaned every 6 months or more frequently with heavy use. This will keep the prefilter clean of air choking lint that can make your system work harder. Vacuum the prefilter with a brush attachment, rinse it with a hose, or soak it in a tub. Do not wash the prefilter(s) in the dishwasher or car wash. Cleaning your Cells 1. A quick cleaning of the cells can be done by simply wiping down the ionizer wires with a damp cloth. This will help boost the efficiency of the air cleaner between full cleaning cycles. Ths quick clean can be done every time the prefilters are cleaned. 2. A full cleaning of the cells will return the air cleaner to its peak efficiency. An easy way to wash the cells is in a tub of hot, soapy water. Just soak the cells until the water cools, agitate and rinse. For details on cleaning cells, see below for Washing the cell(s) in a tub or Washing the cell(s) in your automatic dishwasher. 3. Because the efficiency of the air cleaner remains high even as it loads up with dirt, a full cleaning of the cells can be put off for yearly maintenance and a quick cleaning can be done more often. Those wishing to renew to peak efficiency or with heavier use may want to wash more frequently. Replacing your Postfilter 1. The postfilter is an optional filter that boosts the efficiency of the air cleaner. Do not wash the postfilter because that will neutralize the factory applied charge. 2. The postfilter should be replaced every six months to ensure peak performance.
Mar 03, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
there is a maintenance light on with an exclamation point. What does this mean
It reminds you to do your 'regular scheduled maintenance' of your car.
Example: 50,000-miles, 70,000-miles, 100,000-miles, etc. These warnings are already programmed in your car's computers to simply remind you so the car is kept in top shape, and peak performance.
In some cases, if this maintenance warning is ignored, the car may not keep its peak performance or even break down, having to be towed.
The concerned car's authorized dealer usual performs these regularly scheduled maintenance, but competent independent auto repair shops, such as Midas, are able to do these reagular maintenance as well.
Dec 19, 2009 | 2008 Jeep Liberty
cooling light stays on
If you are referring to the blue temp light on the dash, it stays on until the engine has reached operating temperature. This lets you know the heat will be ineffective and the engine will not be running at peak efficiency during this time.
May 15, 2008 | 2004 Scion xB
202 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
