Tip & How-To about Computers & Internet
Beep sound in desktop pc is due to ram problem .user must check the ram if there is any beep sound problem
Computers & Internet Logo
My dell precision 470 beeps loud for 10 seconds when i turn it on and it has no signal to any monitor any ideas?
Please refer to the beep error codes for your work station here: http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1058075
Usually a 10 second beep is an issue with RAM not detected/installed or an issue with CPU
May 27, 2012 | Dell Precision 470 PC Desktop
steady continuous beeps & computer doesnt boot..?
Its mostly an RAM problem, you need to check you PC RAM. Also use a sytem utility software RegInOut to optimize your PC. RegInOut is a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of Internet Optimizer enhance users web browsing experience.
Dec 15, 2011 | Lenovo 3000 J205 PC Desktop
Will not boot up & I get a continues beep noise
once turn off ur pc abd remove ram and fix it in other place of ram
Sep 25, 2009 | Computers & Internet
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Dec 26, 2008 | HP Compaq d530 PC Desktop
continuous beeping sound
you can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Dec 16, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
346 people viewed this tip
David Payne
David Payne
