Tip & How-To about RIM BlackBerry? Tour 9630 Smartphone
How to adjust contrast settings on a BlackBerry Tour
Whether you are colorblind, curious, or just into weird color schemes, you can change the contrast on your BlackBerry Tour from the normal colors it displays to either grayscale or inverted colors. Here's how:
1. From the main screen, press the BlackBerry button (the one with seven dots) to get to your Home folder.
2. Scroll down until you see the Options folder (the one with the wrench icon) and click on it.
3. Select Advanced Options from the list.
4. Select Accessibility.
5. Go down to the second option, Color Contrast, and use either the ALT key or the space bar to select a new contrast setting. As you select one, the screen will change immediately, so you can preview each one before making a change.
6. When you've settled on a scheme you like, save the change before exiting; press either the BlackBerry button or the Back button and then choose Save.
The contrast setting you choose will affect just about everything you see on your BlackBerry, including Internet content, pre-loaded games, and even third-party applications. When using the Tour's camera or video camera functions, everything will be displayed in normal color, but any pictures taken will immediately appear altered, depending on your contrast setting. Videos are an exception to this rule; if you watch a video on your Tour with either of the alternate contrast settings, the video will still appear in normal color. (Though if you pause the video, the image it pauses on will adhere to your current contrast setting.)
RIM BlackBerry? Tour 9630 Smartphone Logo
My iphone suddenly changed colors. The pictures all look like b/w negatives. The icons are really weird colors. Help. Thank you.
Hello Michel,
In the iphone 3GS there is hidden feature called the "White on Black". It completely inverts the color scheme of your iPhone. The background on the home screen will be white, and the text will be black.All of your native apps will have an inverted color scheme. to disable this feature, Go to Settings then General then Accessibility then Turn of White on Black.wirelessage.jpg
May 19, 2011 | Apple iPhone 3G
how to change the reverse contrast to normal contrast
On the Home screen, click the Options icon.
Click Advanced Options.
Click Accessibility.
Change the Color Contrast field.
Press the Menu key.
Click Save
Dec 31, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
i cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
i want to change the led color on my blackberry
You cannot make any changes in LED colour settings.However, you can set the color contrast of application interfaces, menus, and pop-up screens to Normal, Grayscale, or Reverse Contrast. To change the color contrast, complete the following steps:
  1. In the Options application, click Screen/Keyboard.
  2. Set the Color Contrast field to Normal, Reverse Contrast, or Grayscale.
  3. Press the Menu key.
  4. Click Save.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
1,858 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
