Tip & How-To about Computers & Internet
If your older PC has lost some zip -- An easy thing to check & fix.
After a while, usually several years, your hard disks wear. As this happens the disks will have errors. Windows keeps track of these errors and if they grow too numerous Widows will take actions designed to reduce the possibility of a catastrophic event. One thing it will do is change the method it uses to access the hard disk. It will change from DMA mode to PIO mode and slow you way down. This tip will restore DMA mode so you can get a little more use out of your aging system. You won't need any disks or special software, but you will have to reboot twice.
In Windows get to Device Manager.
One way to get there is click Start, right click My Computer, select Properties, click Hardware tab, click Device Manager button.
In Device Manager, press the + next to IDE ATA/ATAPI controllers.
It should look something like this:
Double click Primary IDE Channel. Click the Advanced Settings tab. If there is no Advanced Settings tab then this tip will not help you, but check the other possibilities (Secondary IDE Channel, other controllers) the same way.
Check to see if the Current Transfer Mode says PIO. PIO stands for Programmed Input Output. It is the slowest mode of disk access. If the Current Transfer Mode is something with DMA (Direct Memory Access), then this tip will not help you as this is the preferred mode.
Check to see if the DMA if available is selected in the Transfer Mode box. If not, select it.
At this point you have determined that you are using PIO mode for one or some of the IDE Controllers and that you have selected DMA in the Transfer Mode. The next thing is to make Windows load the correct DMA driver.
Click the Driver tab.
Click the Uninstall button. Click the OK button. Do this for all IDE Controllers that show PIO mode.
Windows will ask if you want to reboot. Let it happen. Windows will reboot, load the DMA drivers, and tell you it has to reboot again. Let it happen.
Now the DMA drivers should have been installed and some of the snap should return to your PC.
Eventually, Windows will revert back to PIO mode. Your disk is wearing out. Get a new one!
Computers & Internet Logo
hp laptop keeps crashing
May its your hard disk wish have a problem. Try to install your OS on an external hard disk or change the internal hard disk. See what happen. if it show blue screen it may be an hardware error.
Feb 15, 2010 | HP G60-120US Laptop
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Jul 18, 2009 | Computers & Internet
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
my Dell 4700c locks up for no reason at all, start-up issues
I have a feeling your hard drive is going bad if your hearing a clanking sound sometimes. Best way to know is to try to save your important stuff onto your external hard drive if you can and then format your C: drive using a windows 98 boot disk. If it can't go thru the format then you know for sure the drive is bad or if your hearing clanking sounds from the drive while your trying to do any of these steps then the drive is still bad.
Feb 07, 2009 | Dell Dimension 4700C PC Desktop
177 people viewed this tip
David Payne
David Payne
