Tip & How-To about Cameras
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As we all know , PDF is a proprietary format that allows we to
read electronic documents, either on or off line. But the problem is that it can not be editable and
freezes the content . Facing with such problem, we need to convert pdf files to
other formats. While, we always convert it to word , we all familiar with word
which is an editable format .As mac user, you must want to know how to convert
it perfectly, in this case , PDF Converter Mac is the best choice for you.
To begin with you should know the software which is called PDF Converter Mac, PDF Converter Mac is a comprehensive PDF tool to help Mac users
convert PDF to Microsoft Office Word, Excel and PowerPoint for Mac. By
converting PDF files to Office documents for Mac, Mac users can flexibly edit
or reuse read-only PDF files, or extract PDF tables and data to spreadsheet for
easier calculating and editing, or present PDF contents to the public. PDF Converter for
Mac offers many amazing features: Good Preservation; High Efficiency; Support
encrypted PDF Files Conversion; Flexible Options and more. With quick
conversion speed and batch conversion modes, PDF Converter Mac can improve your
efficiency to a large extent.
Now download this PDF
Converter Mac to convert pdf to word on a Mac and install it to your computer,
Following is the details on how to convert pdf to word step by step.
step 1. Import PDF Files
You can add them from the File menu or directly drag files
into the panel. By the way, you can remove the file by dragging it out of the
panel.
step 2. Customize Output Settings
You can set the files in the panel individually. Choose a
file and click setting icon and you can customize the Page Range
and Format.
The default option of Page Range
is All pages; you can also choose Customize and type on the page number that
need to convert.
There are two options of output format. You can choose MS
Office Word (.doc) or Rich Text Format (.rtf) as your need. If you choose the
option Apply to all, the format of current document setting will apply to all
the files in the panel.
step 3. Set Destination Folder
You can set output folder by choosing File-output
settings-output folder. There are two options to select. You can save the
output file in the same folder as source or click Browse to customize the
destination folder.
step 4. Convert PDF Files
Click Convert and all the files will be converted in
seconds. There is a processing bar in the process of conversion. And after
conversion, there will a notification to show you the conversion result. It
will be found that all the original text, layouts, hyperlinks and graphics
would be preserved in an editable Word document.
OK! You successfully
complete to convet pdf to word in mac OS X with a few steps, you can use the
word files easily now.
