Tip & How-To about Computers & Internet
Notebook daily province electricity small coup
Daily use, some electricity skills, also can make using laptop for we extend, especially for IBM Thinkpad R60 Laptop Keyboard some of the endurance of large power ", "control effect is notable.
A notebook, LCD display a large screen brightness, reduce power consumption can be very effectively reduced, extend battery time, dark environment does not need higher brightness, we can reduce it. On a keyboard, most of the key combination adjustment screen brightness, "+ F6 / F7" 12.7mm Fn, specific operations can see random instructions.
Second, the lower screen brightness can effectively reduce the consumption of notebooks
Secondly, the screen saver "cancel", also can increase battery life. In his seat to use, the best friend to cancel the screen saver, set to save electricity or the standby mode, according to different operating system, set up different ways in the next section, we will be introduced in detail. The specific operation for cancellation in desktop screen saver, choose empty place use right "properties", and then select "screen saver", "no" directly determine choice.
Three, based on some common port or hardware "blocked", also can be used in mobile save considerable power. As to pull similar PC card, USB, IEEE1394 etc, or any device interface to disable the cd-rom, wireless network and bluetooth devices, can save Acer ZA3 Laptop Keyboard electricity. Disable hardware equipments, such as common as: drive, right click the "my computer", select "properties", and then select "device manager," in the menu options and find the hardware in the pop-up menu, select "disabled" or "uninstall". For wireless network and the disable bluetooth devices, is accomplished through a shortcut, please see the relevant machine operation manual.
Four, timely monitoring system resources, adjust working condition, reduce process books can also access time, notebook. Through the combination of buttons, "Del + Alt + Ctrl," v process menu, and then to process resource Settings, or operation such as "super rabbit" system, clean, tidy modify system repair operations are not only can also can save energy, space system kill two birds with one stone.
Five,HP 533549-001 Laptop Keyboard the discharge of battery correctly, can enhance battery features, so as to achieve the ideal power supply. Most of the new laptop computers using standard lithium ion battery, the battery is not so much for the full charge of the operation, but they are still weak memory effects, this in notebook computers use 1 years will become particularly obvious,
especially those in power everyday use of users. The ideal discharge operation, should be every 2 months for a full battery discharge, and take place next wipe and ventilation. It can increase the battery life and maintenance performance.
Computers & Internet Logo
I have an IBM Lenovo ThinkPad R60 laptop and the hard drive recently broke. I put in a new one and once i downloaded windows XP and stuff I could not figure out how to connect to wifi, can you help? The laptop has internal wifi.
Welcome to Fixya
Make sure that all driver are installed. Especially the wireless LAN driver. Go to control panel then click on system then click device manager. Look for the network adapter category. There should be no exclamation mark to any of the devices listed there. You can download all your computer drivers here. If everything are ok then all you need to do is to go to control panel. Click network connection. Look for icon named Wireless then click on it. Search your router and connect to it.
Thank you for using Fixya!
Jan 09, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Jul 29, 2009 | IBM ThinkPad R60 Notebook
IBM R60 thinkpad Audio prob
Try to install all the new drivers from this site
http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
i think it will solve this problem. Dont forget to install chipset drivers graphics drivers etc..
Thanks
mohan
Oct 18, 2008 | IBM ThinkPad R52 Notebook
161 people viewed this tip
David Payne
David Payne
