Tip & How-To about Computers & Internet
How To Repair NTLDR or NTDETECT.COM Not Found
If you get an error that NTLDR is not found during bootup,
If you have FAT32 partitions, it is much simpler than with NTFS.
Just boot with a Win98 floppy and copy the NTLDR or NTDETECT.COM files
from the i386 directory to the root of the C:\ drive.
For NTFS:
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. Enter in the following commands (X: is replaced by the actual drive letter that is assigned to the CD ROM drive.
    COPY X:\i386\NTLDR C\:
    COPY X:\i386\NTDETECT.COM C:\
  6. Take out the CD ROM and type exit
Computers & Internet Logo
convert ntfs to fat32
First of all delete the partition that you wish to convert. This is done by going into Disk Management: right click on My Computer > Manage > Disk Management, which is found under the Storage section. Right click the partition you wish to remove, and click Delete Volume This will erase the partition. Once you have done this, you must re-create the partition. This is done by right clicking on an unallocated region of a disk, and selecting Create Partition. Then click Create Logical Drive. Bear in mind that Windows cannot format a FAT32 partition that is any larger than 32GB. This is the case because FAT32 is terribly inefficient on volumes that are larger than 32GB: fragmentation becomes a serious problem.
Or you can use partition magic software to convert it.
Oct 20, 2011 | Computers & Internet
Hi, I deleted some files by mistake on an ols ACER
Initially check if you have ant cd/dvd left in your cd driver.if yes remove it and then check by restarting it again.
if the problem still exists -- click on the link below to get help from microsoft support for this error:--
http://support.microsoft.com/kb/320397
OR
you will require a xp disc to fix it :--
For NTFS:
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 01, 2009 | Acer Computers & Internet
how cAN I INSTALL WINDOW 98 OVER WINDOWS XP IN THE NTFS FILE SYSTEM
For that first you need to delete that ntfs patition becasue win98 disk not supports ntfs.
For deete partiotion you can use dm tool or winxp bootable disk then delete NTFs partition then boot computer with win98 disk thats it.
Aug 19, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
98 loading error message
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
May 29, 2008 | Microsoft Windows 98 for PC
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
155 people viewed this tip
David Payne
David Payne
