Tip & How-To about Computers & Internet
How To Identify Faulty Device Drivers
If you are having problems with lockups, blue screens, or can only get to safe mode,
often the problem is due to a faulty device driver.
One way to help identify them is through the use of the Verfier program
  1. Start / Run / Verifier
  2. Keep the default of Create Standard Settings
  3. Select the type of drivers you want to confirm
  4. A list of drivers to be verified on the next boot will be shown.
  5. Reboot
  6. If your computer stops with a blue screen, you should get an error message with the problem driver
  7. To turn off the Verifier, run verifier /reset
Computers & Internet Logo
i install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
dell xps i5 laptop windows xp install blue screen problem
Deva,
Please follow the link below for a complete reinstall of Windows XP without losing any data. I have done it many times on different machines and there are no problems.
http://www.informationweek.com/shared/printableArticle.jhtml;jsessionid=XIR0ZCH5SDIMZQE1GHPSKH4ATMY32JVN?articleID=189400897
Feb 17, 2011 | Computers & Internet
blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
I GET A BLUESCREEN AND CURSOR WHEN MY LAPTOP BOOTS
Press F7 while windows statrs and boot the system wih safe mode check whether you are getting blue screen.if you are not getting blue screen, Then the problem was due to improper driver installed for any device. Uninstall the same in safe mode.
Dec 03, 2009 | Toshiba Satellite Pro L300 Notebook
175 people viewed this tip
David Payne
David Payne
