Tip & How-To about Computers & Internet
Network Connection Always Shows Access Denied
If you are always getting Access Denied errors when trying to connect to a XP computer,
and you know you have the correct user names and passwords on the computer,
the solution may be a simple registry edit.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlSet / Control / Lsa
  3. Change the value of a key called "restrictanonymous" to 0 instead of 1
  4. Don't change "restrictanonymoussam" value.
  5. Reboot
Computers & Internet Logo
Warning: mysqli::mysqli(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: YES)
Open up the PHP Config File Config.php (File name can vary) where the MySQL DB connection details are entered.
Change the machine source name, user name and password as per the current system config.
If still not fixing, go to the PHP line causing the issue and echo the connection details, and see if correct values are there.
Mar 04, 2013 | Computers & Internet
I set up a hotmail account and am trying to link it to my Outlook XP Professional application. When I hit send/receive, I get error 0x800CCC33 - Access to account denied; verify that your username & password is correct. I have verified that the information is correct. What is wrong?
I did find out that it is linked to the profile. I haven't deleted my profile yet because I haven't backed it up. However, other users on the same computer can send just fine. If you can, delete your windows profile and try it again. A re-install does not solve the problem because there is still profile information that isn't deleted when Outlook 2007 is uninstalled. Let me know if this helps and I am going to see if there is another solution so I don't have to delete my profile.
Jul 16, 2010 | Microsoft Windows XP Professional
cannot log on to laptop
What is your OS ?? If it is windows xp and you didnt setup admin password when your sysrem was instaled you can try restart your laptop, When will start rebooting wait till you see second boot screen and start pressing F8 when you will see emergancy menu click to save mode, Log on as Admin (not your name) and when system willl started go to: control panel,user accounts,logon as admin,go to your profile(account with your name) and press remove password. then restart your computer. Your password will be gone.
Dec 27, 2008 | Computers & Internet
NT4 sees XP Pro in network neighborhood, but access denied
If you arent too worried about security since it is at home, enable the guest account on the windows XP machine, also disable the firewall on the XP machine ( it is on by default )
let me know
Oct 29, 2008 | IBM NetVista PC Desktop
i can't connnect to intrnet
SYMPTOMS loadTOCNode(1, 'symptoms'); When you try to establish a dial-up connection after you upgrade your computer to Microsoft Windows XP from Microsoft Windows 98, from Microsoft Windows 98 Second Edition, or from Microsoft Windows Millennium Edition (Me), you may receive an error message that is similar to one of the following: Error 721: The remote computer is not responding. Error 678: The remote computer failed to respond. Error 691: Access was denied because the user name and/or password was invalid on the domain. Error 777: The connection attempt failed because the modem or other connecting device on the remote computer is out of order. To resolve this issue, contact the hardware manufacturer to inquire about how to obtain and install the latest Windows XP-compatible driver for the modem or download an XP driver for the modem
Feb 14, 2008 | Computers & Internet
179 people viewed this tip
David Payne
David Payne
