Tip & How-To about Computers & Internet
Faster DOS Printing
If you are experiencing slow printing for DOS programs with Windows2000
  1. Go Start ' Run ' Regedit
  2. Click Hkey_Local_Machine
  3. Click on System
  4. Click CurrentControlSet
  5. Click Control
  6. Go to the bottom of this part of the list and click WOW
  7. Click LPT timeout and change it to a 3
Computers & Internet Logo
how i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
optical drive not playing
This may not apply but it's worth a shot....
Click Start > Run
Type Regedit in the run box.
Open "HKEY LOCAL MACHINE > SYSTEM > CURRENT CONTROL SET > CONTROL > CLASS >
Look for keys called "Upper Filters" and "Lower Filters" and delete any values inside those keys, then restart the machine.
Note: If using Vista, be sure to right-click Regedit in the program list and choose "Run as Administrator", otherwise it won't let you change the values of the key.
Hope this helps,
Techneck09
Jun 10, 2008 | Dell Dimension 4700 PC Desktop
my cd rom drive is not appearing on my computer i have an equium a210
follow these steps
Click start
Click run
type regedit
keep clicking the plus sign next to
Hkey local machine>>System>>Current ControlSet>>Control>>Class
Under class click on the first folder that starts fro 4D and it would be like 4D36E965
Now at the right hand side you will see options like upper filters and lower filters just right click and delte them
If you dont see both of them no worries delete the one that you see .After this restart your system.and check
May 25, 2008 | Toshiba Computers & Internet
127 people viewed this tip
David Payne
David Payne
