Tip & How-To about Computers & Internet
Services You Can Disable
There are quite a few services you can disable from starting automatically.
This would be to speed up your boot time and free resources.
They are only suggestions so I suggestion you read the description of each one when you run Services
and that you turn them off one at a time.
Some possibilities are:
  • Alerter - Sends alert messages to specified users that are connected to the server computer.
  • Application Management - Allows software to tap directly into the Add/Remove Programs feature via the Windows Installer technology.
  • Background Intelligent Transfer Service - The Background Intelligent Transfer service is used by programs (such as Windows AutoUpdate) to download files by using spare bandwidth.
  • Clipbook - ClipBook permits you to cut and paste text and graphics over the network.
  • Error Reporting Service - Allows applications to send error reports to Microsoft in the event of an application fault.
  • Fast User Switching - Windows XP allows users to switch quickly between accounts, without requiring them to log off.
  • Help and Support - Allows the XP Built-in Help and Support Center to run.
  • IMAPI CD-Burning COM Service - You don't need this if you have other software to create CDs.
  • Indexing Service - Indexes contents and properties of files on local and remote computers; provides rapid access to files through flexible querying language.
  • IP SEC - Manages IP security policy and starts the ISAKMP/Oakley (IKE) and the IP security driver. If you are not on a domain, you likely don't need this running.
  • Messenger - Transmits net send and Alerter service messages between clients and servers. This is how a lot of pop-up windows start appearing on your desktop.
  • Net Logon - Supports pass-through authentication of account logon events for computers in a domain. If you are not on a domain, you don't need this running
  • Network DDE - Provides network transport and security for Dynamic Data Exchange (DDE) for programs running on the same computer or on different computers.
  • NT LM Security Support Provider - Provides security to remote procedure call (RPC) programs that use transports other than named pipes.
  • Performance Logs and Alerts - Collects performance data from local or remote computers based on preconfigured schedule parameters, then writes the data to a log or triggers an alert. If you don't need to monitor your performance logs, then you don't need this service.
  • Portable Media Serial Number - Retrieves the serial number of any portable music player connected to your computer
  • QOS RSVP - Provides network signaling and local traffic control setup functionality for QoS-aware programs and control applets.
  • Remote Desktop Help Session Manager - Manages and controls Remote Assistance. If you are not using Remote Desktop you don't need this service.
  • Remote Registry - Enables remote users to modify registry settings on this computer.
  • Routing & Remote Access - Offers routing services to businesses in local area and wide area network environments. Allows dial-in access.
  • Secondary Login - Enables starting processes under alternate credentials. This is what allows you to run an application as another user.
  • Smart Card - Manages access to smart cards read by this computer.
  • Smart Card Helper - Enables support for legacy non-plug and play smart-card readers used by this computer.
  • SSDP Discovery Service - Enables discovery of UPnP devices on your home network.
  • TCP/IP NetBIOS Helper - Enables support for NetBIOS over TCP/IP (NetBT) service and NetBIOS name resolution. This should not be needed in today's network environment.
  • Telnet - Enables a remote user to log on to this computer and run programs, and supports various TCP/IP Telnet clients.
  • Uninterruptible Power Supply Service - Manages an uninterruptible power supply (UPS) connected to the computer.
  • Universal Plug and Play Device Host - Provides support to host Universal Plug and Play devices
  • Upload Manager - Manages synchronous and asynchronous file transfers between clients and servers on the network.
  • Volume Shadow Copy Service - Manages and implements Volume Shadow Copies used for backup and other purposes.
  • Web Client - Enables Windows-based programs to create, access, and modify non-local files across the Internet.
  • Wireless Zero Configuration - Provides automatic configuration for the 802.11 adapters
  • WMI Performance Adapter - Provides performance library information from WMI HiPerf providers.
Computers & Internet Logo
my Labtop boot only the windows logo and stop there, what is the solution
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 22, 2012 | HP Pavilion dv7-1132nr Notebook PC
when i switch it on it boot alright the after booting it tels me that logon process initilla
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 10, 2012 | Samsung N150 (36725723009) Netbook
my pc speed is too slow. sometime it hag very much .please i request you to give mesome solution
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 07, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
wireless adapter cannot find enough free resources
please try to see if this steps will work. change the startup type of your wifi card into automatic by:
• click START, click RUN
• type services.msc
• look for WLAN Autoconfig and double click it
• change start up type into automatic and stat the process
• hit Apply and the OK
• restart the computer and also restart your wireless router
Hope these helps.
Jun 02, 2010 | MSI (CB54G2) 802.11g/b Wireless Adapter
217 people viewed this tip
David Payne
David Payne
