Tip & How-To about Cell Phones
How to make ur nokia phone work good wen it givs any problem....
Just switch off ur phone n remove ur battery n aftr few seconds insert the battery n exatly aftr 5sec switch on ur mobile...nw enjoy.... it is workng for me....
Cell Phones Logo
my nokia n 86 is not getting switched on after charging it overnight. What can be done to it to switch it on?
First Option:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Second option:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
Dec 07, 2012 | Nokia N86 Smartphone
my nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
Apr 19, 2011 | Nokia 3110 Cellular Phone
how to open the gprs in samsung sgh-c160
fistly u enable gprs connection on ur connection, aftr that u save ur gprs setting.
Now u install pc suit on ur system, & connect ur phone through cable. & enjoy
Nov 21, 2009 | Computers & Internet
it is frozen it will not move
switch off ur mobile phone and remove the battery and the sim card from it and wait for five minutes and then insert the sim card and the battery and ur restart the mobile and ur problem gets resolved
Jun 15, 2008 | Motorola Mobility RAZR V3
the phone is only showin nokia
beacause of n-gage cant handle video tone software memory is blocked by that so phone is unable to boot up. do following remove MMC from your mobile after that switch on mobile without MMC it will switch on then format mobile with *#7370# code. default unlock code is 12345. after fully formatting mobile insert MMC and immediately format MMC also. [remember that data will lost from both mobile and MMC during this procces] i think mobile is ok now. but if you cant able to switch on mobile without mmc then you must have to visit nokia service centre.
Aug 17, 2007 | Nokia N-Gage QD Console
109 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
