Tip & How-To about Boating
Last minute pool vacuumning
Did you ever want to just get the pool vac'd., without getting out the robot if you even have one, or pulling out the vacumn and hooking up the hoses, having to purge all the air out of the system just to get it ready.....you know the drill....and to make matters worse its real hot out!!
her's what i have found in my years of pool cleanup blunders, Put the pool selector valve to pool drain, get a long adjustable handled pole with a leaf type pool brush attachment, very slowly push the grit on the liner towrds the pool drain, do it gently and stop, wait until the smokey looking water clears(this means it went into the drain port and is being filtered out in the cannister).
Do this to the entire pool but dont rush it, after you are done check the PH and Chlorine etc. adjust, backwash the filter if your filter has a backwash system, and off you go onto another home project, this one just saved you a ton of precious time!!!
If you have the inground pool cartridge filter system you should remove the filter/filters and hose them out twice a year to keep them clear, when they start to look and act dirty and they cant get clean by hose take them to a pool pro and ask him to chemical bath them, thisfilter problem will be noticable when you see the pressure rising too high on your filter tank, it means the filter/filters are getting clooged and need attention.
Happy Homeowning!!
Boating Logo
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Heater and Air conditioner work bur air flows from window vents only. Can't change direction of air flow to different vents.
There may be a couple of items to look at here.... but the most common problem is a source of vacumn to the pneumatic operation of the heat/a/c vent doors....if vacumn is not distributed properly to the vents you command it is assumed that there is either no vacumn to the selector swith panel(broken vac. line,kinked vac. line, defective in dash a/c control panel) or under the hood a defective vac./heater control valve that is stuck,frozen, not allowing the vacumn to pass through it to supply the indash pneumatic controls and/or panel.
Most vacumn systems that i have ever came in contact with incorporate a vacumn supply tank(nothing more then a round plastic vac. resevoir) which is used in sequence with the a/c heater controls, its purpose is to keep an even vacumn supply to all command points continously while the vehicle is being driven, without this supply one will experience the a/c coming from various different non selected dash vents upon acceleration, this is a direct relation to the tank either being defective(leaking vacumn) or its supply hose(usually vey tiny rubber/plastic tubes) being pinched or broken not allowing the vacumn to the supply tank.
listen for vacumn leaks(hissing sound), look for the obvious...broken vacumn lines or hoses, also check for a defective one way vacumn valve on some pneumatic controlled door vent systems(these valves are inserted in a vacumn line one side being the ""in" port and the other side of it being the "out" flow port,typically if these dont work the vents will also devert your a/c or heat all different ways through your dash.
to check these valves, simply remove from the vacumn hose, and apply vacumn to one side,if vacumn flows through the valve, apply the same vacumn to the opposite side of the plastic valve, if vacumn flows through on the opposite side the valve is bad, it should only allow flow from one side not the other. These valves are small and are usually white or black plastic and look like the old vacumn dash pots used on the old carbureated engines only smaller with one small hose in and one small hose out.
May 16, 2010 | 2004 Buick Rainier
986 people viewed this tip
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
