Tip & How-To about Video Game Consoles & Games
How to fix 1 red ring of death
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove, this how ever is not easy to do and will void any warranty you have left so double check your warranty as this part will be covered, taking the case of is not easy to do and you can cause more harm than good if you are unsure what you are doing.
i repair these myself and only charge if the problem is solved you never know if its just the dvd drive or if the unit has over heated and caused the dvd drive to fail, if this is the case then it wont be long before you get the dreaded red reing of death, which is 3 red lights lit up
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Video Game Consoles & Games Logo
my zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
got a green light in the centre and bottom rt is red,can`t do a thing with it,any ideas?
Sep 16, 2010 | Microsoft Xbox 360 Console
My 360 will play movies all day long, but when I put a game in it plays for approximately 3 minutes and shuts off. The lights on the left side of the power button flash red. What is the deal?
Sep 15, 2010 | Microsoft Xbox 360 Console
How do I Fix flashing green and red light
What error number does it have on the screen? It should be a white number in one of the corners of the screen. If you find out what it is, then select add more details in this question and say what the error number is.
Dec 22, 2007 | Microsoft Xbox Console
266 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
