Tip & How-To about Video Game Consoles & Games
How to fix ylod on ps3
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Video Game Consoles & Games Logo
| am getting 8002f14 error when I am launcing app_home/PS3_Game what I havo to do??
Hi,the PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
* Bad power supply.
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
yellow light of death man!!
* Bad power supply.
Sep 24, 2010 | Sony Playstation 3 (PS3) Console
cut off and light is red; quickly you see green;yellow then flashing red.
Sep 22, 2010 | Sony Playstation 3 (PS3) Console
System shut down. Red light started blinking. After red light was blinking a yellow light was shown and the entire system was shut down.
* Bad power supply.
Sep 20, 2010 | Sony Playstation 3 (PS3) Console
PS3 turns green then yellow then red
* Bad power supply.
Sep 16, 2010 | Sony Playstation 3 (PS3) Console
308 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
