Tip & How-To about Computers & Internet
How to Shutdown or Turn off your Computer Properly
There's nothing wrong with powering your laptop, or desktop, down by clicking the Power button and letting it go into standby, sleep, or hibernate mode, much of the time. On your laptop, usually just tapping the Power Button will perform the same function as the following instructions.
When doing this, click on the symbol just to the right of the Start button. This allows all open windows to be suspended properly, with current data saved. When you startup the next morning, your open programs will still be running in the background. Clicking on your logon will have your right back where you left off.
If you see the same symbol with the exclamation mark , click and leave the computer alone, because it will be in the process of installing important updates before shutting down.
Nothing beats a complete "Shut Down" through the Start menu in the lower left-hand corner of your Windows screen. Mouse-over to the far right icon, and click on Shut Down in the popup window. All your open programs will be closed properly, data saved, and memory and cache cleared. This is like going to bed at night with nothing on your mind, sleeping soundly, and waking up refreshed in the morning.
Then, when the computer is powered up the next time, it will be operating at its optimum performance levels without being "bogged" down with excessive leftover garbage from previous sessions. It leaves you with a fresh start-up the next time you are ready to use your computer.
To summarize, tapping the Power button most of the time, and allowing the computer to enter sleep mode, is fine. Occasionally, do a complete Shut Down to clear everything out of memory. Your laptop/desktop will thank you...lol.
Regards, Bill
09-19-10
Computers & Internet Logo
acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
proper shut down
Hi doodu13appa,
Nothing beats a complete "Shut Down" through the Start menu in the lower left-hand corner of your Windows screen. This allows all open windows to be properly closed, with current data saved, memory and cache cleared. This is like going to bed at night with nothing on your mind, sleeping soundly, and waking up refreshed in the morning.
Then, when the computer is powered up the next time, it will be operating at its optimum performance levels without being "bogged" down with excessive leftover garbage from previous sessions. There's nothing wrong with powering your laptop, or desktop, down by clicking the power button and letting it go into standby, sleep, or hibernate mode, much of the time. It leaves you with a quick-startup the next time you are ready to use your computer, and most of your open programs will still be running in the background. Clicking on your logon will have your right back where you last left off.
Sep 19, 2010 | Computers & Internet
198 people viewed this tip
David Payne
David Payne
