Tip & How-To about Computers & Internet
Rotate Screen on windows
Little trick on windows:
You can rotate your entire screen orientation, when press the combination key:
Ctrl + Alt + [Arrow Key].
Up arrow - Return the orientation to normal;
Right, Left and Down, rotate screen
It's not sure it will work on all systems.
Old graphic or integrated may not work.
Computers & Internet Logo
How can I change orientation on a Panasonic Touchbook?
If you have Windows XP then you should be
able to change the screen orientation as follows:
Hold down both the "Alt" and "Ctrl" Keys simultaneously.
While holding down these two keys, press either
the Up Arrow Key or the Right Arrow Key.
Release all three keys and the screen will have
rotated 90 degrees.
You may also have to try Alt + Ctrl + Down Arrow
or Left Arrow. You also might have to repeat the
key combination 2-3 times until you are in the
correct orientation.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Apr 28, 2014 | Panasonic Toughbook CF-27 Notebook
Dropped Laptop and Screen is now Sideways
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Sep 08, 2012 | HP Computers & Internet
rotate screen back to horizotal
or
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
my screen was reverse how to adjust correct place
or
hope this helps
May 31, 2012 | Computers & Internet
HP 1740 screen image rotated 90 degrees - how to move back
On most video cards the key combinations of ctrl+alt+left arrow, ctrl+alt+right arrow, ctrl+alt+up arrow or ctrl+alt+down arrow will allow you to rotate the screen display in any direction. Each key combination will rotate the screen in the direction of the key press.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 23, 2010 | HP Pavilion F1703 17" LCD Monitor
198 people viewed this tip
David Payne
David Payne
