Tip & How-To about Computers & Internet
Cleaning out Temporary File folder made easy
Create a text file called "Clean Temp Folder.cmd" in a convenient location.
Paste the following content into the file and save:
echo off
echo Cleans out the System Temporary file folder
echo off
pause
Del "%HOMEPATH%\Local Settings\Temp\*.*" /s/f
Del "%HOMEPATH%\Local Settings\Temp\*.*" /ah
pause
Close the file and double-click to execute it. You will be asked to confirm deletion of the files, including hidden files. It does not clean out sub folders and their contents located in the temp folder. If you haven't done this in a long time you freed up quite some drive space and picked up some speed.
Computers & Internet Logo
HOW CAN I PRINT FOLDER CONTENTS SIMILLAR TO THE DOS CAOMMAND TREE > PRN
Go to start button. In the start menu click RUN and in the box that opens type "cmd"
In the CLI go to the directory of the folder whose content you want to print and type the following and press enter to create list.txt file first before printing.
dir /b /s /on >list.txt
This will give you a text file (list.txt) in the folder, that you
can manipulate, print etc. in a text editor or
word processor. In order to redirect the output
directly to your printer, instead of a text file, type:
dir /b /s /on >prn
Aug 25, 2010 | Microsoft Computers & Internet
Create a password protected folder without any special software
I found that your post is quite helpful to me but can you help or can i request another set of codes where the password that i type will change in asterisk rather on the real word of the password.
Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
windows automatic shutdown
1. create a new text file by opening notepad. 2. paste the following in the text file:
echo off shutdown.exe -r -t 00
3. save the text file but change the .txt file extention to .bat. 4. under control panel, open task scheduler. 5. schedule a new task to run your new .bat file, whenevr the pc should be shut down.
good luck.
Aug 26, 2009 | Computers & Internet
hp g6000 running very slow any suggestions.
The HP g6000 slow issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the solution http://www.speeduphp.com/fix-slow-hp.html to give a free & full scan of your slow HP PC to find & fix all possible issues.
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance.
Mar 09, 2009 | HP Pavilion dv6000z Notebook
272 people viewed this tip
David Payne
David Payne
