Tip & How-To about GPS
What to do when you forget your Garmin PIN.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
GPS Logo
unlock nuvi 670
Sep 30, 2010 | Garmin nuvi 670 GPS Receiver
unlock garmin nuvi 250w
Sep 09, 2010 | Garmin nuvi 250W GPS Receiver
pin code unlock
You have Garmin Lock activated and there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it).
May 31, 2010 | Garmin nuvi 200W GPS Receiver
unlock pin nuvi 350
Apr 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
unlocking garmin nuvi 200
I've been trawling for unanswered questions; this information may be too late for you (or perhaps it may help you resurrect a useless machine which you have put away) but it will certainly help others searching for advice with the same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it. There is no hack, crack, bypass or any other reset option.
Jun 08, 2009 | Garmin nuvi 200W GPS Receiver
1,426 people viewed this tip
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
