Tip & How-To about Office Equipment & Supplies
What to do when your printer will not print.
If your unit does not respond at all to print commands and you know that it worked OK previously you could have a corupt driver. First make sure that no wires are disconnected. If the unit is hooked up and turned on, try the following.
To check the status Click on "Start" then "Control Panel" then "Printers and other Hardware" then "View installed printers and fax printers" then click on the printer icon in question.
This should open a new window. At the top click on "printer" scroll down to "properties" and right click on it.
This will open another new window where you can print a test page. If the unit prints a test page but some parts of the print are missing I would replace the ink cartridge or try to clean the nozzles under the maintenance tab in the properties window. If cleaned once or twice and still not printing all parts of caracters I would replace the cartridge.
If the unit gives a message such as " cannot find printer" or "printer not ready" you probably have a bad driver and should reinstall a new one. This is not difficult but requires internet access to download the newest driver.
The manufacturers website would be the best place to get the most up to date driver. To find your particular site google ' manufacturer (ie Canon, HP, Lexmark, etc) drivers'.
Choose the manufacturers site from the list presented. Click on the link to go to the drivers download page. Follow the on screen instructions to locate and download your driver. Install it on your computer and restart the computer.
Now you should have the newest driver and if problems still persist you probably have an electronic control board issue and will need a new printer.
If this was the problem your unit should now print.
Thanks for using FixYa and for the great rating.
hardrocko
Driver
if the copier is not responding to print commands then you need to verify that the ip address listed in the print driver is the same as the one on the copier and that the copier's ip subnet and gateway are apropriate for your network...
Dec 29, 2009 | Sharp AR-5320 Black and White Copier
printing problem
Dear sir,
install new oparating system and attach data cable in your pc then show a new hardware .
This printer is auto plug &play not driver requarments.If you are not success then change data cable with new one.
Thanks
Aug 24, 2009 | HP LaserJet P3005n Printer
how to do rip and hold for 1r400
NO.
Command Workstation Use For Xerox Not For Canon. OK
Dec 12, 2008 | Canon imageRUNNER 400S Copier
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
353 people viewed this tip
jasbo
jasbo
