Tip & How-To about Computers & Internet
Increase HDD Speed
Run SYSEDIT.EXE from the start & then Run command.
Expand the system.ini file window.
Scroll down almost to the end of the file till you find a line called [386enh].
Press Enter to make one blank line, and in that line type
Irq14=4096
Note: This line IS CASE SENSITIVE!!!
Click on the File menu, then choose Save.
Close SYSEDIT and reboot your computer.
Done. Speed improvement will be noticed after the computer reboots.
The most speed improvement is visible with IDE drives, however there arereports that this tweak also does good for SCSI disks. In any case, it won'tharm your system, so why not try it yourself and let me know what you find
Computers & Internet Logo
Pelco dx7000 password
To reset the password for the DX7000 follow these steps: Reboot the system During the boot process, before "Starting Windows" message comes up, press the F8 key repeatedly to enter Safe Mode When the boot options menu comes up, select boot to command prompt only If you get the scan disk screen, you've gone too far and have to reboot. At the command prompt "C:\>" type cd windows and press enter. At the prompt C:\WINDOWS>" type edit system.ini and press enter. When the edit screen opens up, scroll down to the line beginning with the word "shell" Insert a semicolon (;) before the word shell = ;shell Save the file, exit, then reboot the system (You may have to hit ALT on the keyboard to get the File menu to come up) Press ALT+F followed by X and select Yes to the save and exit prompt Press CTRL+ALT+DEL to reboot. The system should now boot to a regular desktop, edit the system registry: Click on the Start button Select Run In the Open field, type in REGEDIT, then click on OK Find the password entry and delete the password: Double click on HKEY_CURRENT_USER Double click on SOFTWARE Double click CyberNetic Double click DVR Double click 1.0 On the right-hand side, locate the word Password and double click it Delete the contents of the Value Data field and click OK Close the regedit window Make the system bootable into DX7000 software: Click START Select Run In the Open field, type SYSEDIT then click OK Click on the SYSTEM.INI window within the System Configuration Editor window Locate the SHELL statement and remove the semicolon that was placed there earlier Close the System Configuration Editor window Click OK when it prompts you to save changes made to SYSTEM.INI file Restart the system (Click START > SHUT DOWN > RESTART) Click OK
Apr 01, 2012 | Pelco DX1000
My netbook will not start because is says that the following file is missing or corrupt. <Windows root>`system32`ntoskrnl.exe . It says to reinstall a copy of the file but i do not know what to do.
hi
perapre yourself with your Winodws OS disk
then carefully read and follow these isntructions.. patience is required to sucessfully resolve this issue.
To resolve this issue, use either of the following methods.
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base:
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 3 loadTOCNode(2, 'resolution');
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand :\i386\ntoskrnl.ex_ :\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand :\i386\ntkrnlmp.ex_ :\Windows\system32\ntoskrnl.exe Note In these two commands, the placeholder represents the drive letter of your CD drive, and the placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 09, 2011 | Computers & Internet
Aspire M1100 boot up problem
Method 1
Method 2
Method 3
expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
Method 4
Jan 11, 2009 | Acer Computers & Internet
394 people viewed this tip
David Payne
David Payne
