Tip & How-To about Computers & Internet
To Use Full Processor's L2 Cache by Windows
Just Goto Start Menu---->Run----->Type "REGEDIT>EXE "(Without "") and
Press Enter.
Just Navigate to the Following Key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SessionManager\Memory Management
Computers & Internet Logo
certificates problem
  1. Click Start , type regedit in the Start Search box, and then press ENTER.
  2. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
  3. On the Edit menu, point to New , and then click Key.
  4. Type the following key name, and then press ENTER: FEATURE_ERROR_PAGE_BYPASS_ZONE_CHECK_FOR_HTTPS_KB954312
  5. On the Edit menu, point to New , and then click DWORD Value.
  6. Type iexplore.exe , and then press ENTER.
  7. On the Edit menu, click Modify.
  8. Type 1 , and then click OK.
  9. Exit Registry Editor.
Oct 31, 2010 | Computers & Internet
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
genuine microsoft solve problem
Activate Windows XP Without Registration "
1. Type Regedit on the Run Menu
2. Go to Hkey-Local_Machine/Software/ Microsoft/WindowsNT/CurrentVersion/
WPAEvents
3. Select OOBETimer (Reg-Binary) and Press Enter. Now You will See a Set of 12 Keys.
4. FF D5 71 D6 8B 6A 8D 6F D5 33 93 FD
{just delete D6 (4th entry) and replace it with C4}
5. Exit Regedit.
6. Type "%systemroot%\system32\oobe\msoobe.exe /a" on the Run Menu (without quotes)
7. Select "Yes I want to telephone a customer service representative to activate windows".
8. Click Next
9. Select "Change Product Key"
10. Put these keys
QMDGV-QRC2B-XF6JB-GRGHK-W9DRC
11. Select Update
Dont worry about asking again to register , close that
Restart the system and repeat steps 6 to 11, now the process will tell you that Windows XP is already activated.
rate me
it will work for you 100%
don't forget to reply
Jan 07, 2009 | Microsoft Windows XP Professional With...
125 people viewed this tip
David Payne
David Payne
