Tip & How-To about Computers & Internet
How to Import flip video to iMovie and edit flip video
Why choose Mac Flip Video Converter for import flip video to iMovie?
If you recorded a few video clips with the Flip Mino or Flip Ultra, and when you tried to import the video files from flip video camcorder to into iMovie or tried to edit the flip videos, only to find out that you couldn't. Apparently, you're not alone, because you'll find there are plenty of other people with the same problem.
First:Flip video's built-in software Flipshare can combine clips or editing flip videos,but the editing function is so less for the flip users.
Second:iMovie has different versions, each version has more or less difference, the video formats they can support has its limitation, it only supports mov, dv, hdv,MPEG4, etc. But for the flip camcorder(include the Flip Ultra, the Flip Ultra HD, the Flip video Mino, and the Flip video Mino HD) just produce flip video in mp4 or avi format, avi flip video can't recognized by iMovie, so converting flip avi to the formats compatible for iMovie, you can import your flip file to iMovie without any difficulties.
With all the problems above,what can we do to import flip video to iMovie?-Introduce a best flip video to iMovie converter for mac,which can let you import your flip video to iMovie without any difficulties
Mac flip to iMovie converter is a program specially designed to make Flip Mino and Flip Ultra work well with iMovie, iTunes and QuickTime, it can convert flip video to various common formats like mpeg4, mpeg2, mov, dv that compatible with the iMovie, mov for QuickTime.
Edit flip video in iMovie - Import flip to iMovie and edit flip video iMovie.
Part one: How to import flip video to iMovieHD/ iMovie 08 /iMovie 09 with mac flip to iMovie converter.
Step 1.Free download,install and run flip to iMovie converter
Step 2.Set an output format
Choose 'MPEG-4' for iMovie 09, iMovie09 supports the most popular video formats like AVCHD and MPEG4, and even the new iFrame video format.
Choose 'MPEG-2' for iMovie08, iMovie08 works with many tapeless camcorders that record to flash memory, HDD,or DVD media.
Choose 'DV' for iMovie HD."
Step 3.Set a destination for the converted flip video
Click the "Open" button in the main interface of Flip Video to iMovide Converter,and the choose the destination as you want.
Import flip video to iMovide with Flip Video to iMovide converter
Step 4.Step5:Start the conversion
Click "convert" button to start converting flip video to iMovie with mac flip to iMovie converter.
Part two: Edit flip video on iMovie
Now your flip videos have been converted to iMovie supported video formats. Launch your iMovie and follow the steps below to edit your flip videos:
Step 1.Trim video length
You are able to get any part of the source Flip to iMovie converter for mac by specifying the exactstart and the end time by dragging the slider bars. Thus, when you are trying to convert flip video on mac, you could casually limit the video or audio film's length according to your own will.
Step 2.Crop video
Select one video clip, click "Edit"->"Effect" and click on the Crop button to crop it.
Step 3.Adjust video
Click "Edit"->"Effect",and set the brightness,saturation,contrast as you like.You can also set special video effects including old film,grayand emboss to adjust flip video.
Tips:
1. This flip to iMovie converter mac support batch conversion to save your time and trouble, you can load many flip files at the same time, besides it can merge your separated flip files into a succesive one by click 'Merge into one flie'button.
2. Flip to iMovie converter supports instant preview both input and output video effect, it provides two priview windows for you to watch what you have modified, in addition, interesting pictures can be captured from playing video.
Computers & Internet Logo
Jumpy Video in Flip Video Ultra HD
If you recorded a few video clips with the Flip Mino or Flip Ultra , and when you tried to import the video files from flip video camcorder to into iMovie ‘08, only to find out that you couldn’t. Apparently, you’re not alone, because you’ll find there are plenty of other people with the same problem.
Some Flip video camcorder will record video in mp4, but some in mpeg-4 formatted AVI files, the problem is iMovie won’t recognize AVI, you will need to convert AVI to DV Stream before import into iMovie.
Fortunately, there is a simple yet effective way to work this out, check it out: Flip video converter for Mac [/url] is a program specially designed to make Flip Mino and Flip Ultra work well with iMovie, iTunes and QuickTime. It can convert flip video to DV, m4v for iMovie, and convert flip video to QuickTime. mov for QiuickTime. Mac Flip video converter is Mac friendly program, which is compatible with PowerPC and Intel Processor. You can count on it.
How to use Mac Flip Video Converter
Step by step to import flip video to iMovie files on Mac OS X.
Step 1 Download and install flip video converter for Mac
Flip video converter for Mac released its latest version 3.3.8 recently, and there are two folders included in the program, one is for Intel Processor, the other is for PowerPC, please choose wisely.
[img][/img]
Step 2 Import flip video to flip video converter
You will need to convert flip video files to DV or M4v that to be importable by iMovie.
If you have many video clips and want to load them at one time, just go ahead, the batch mode will let you do without any problem.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import.jpg[/img]
Step 3 Select the output format and output path for the video need to convert
In your case, you can select .DV as the output format. On the bottom of the panel, select .dv in the drop down list menu next to Profile…
Select a location in the drop down menu next to Destination.
Click Open…button will let you directly locate where the output file is stored.
Step 4 Convert flip video to iMovie compatible format
Hit Convert…button, this will instruct the program to convert the list of flip video immediately
Please wait patiently till the progress bar says conversion done.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/conversion.jpg[/img]
Step 5. Now open up iMovie ‘08, and go to File > Import Movies, browse for them, and import to your heart’s content. That’s it!
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import-to-imoive.jpg[/img]
Jul 18, 2009 | Pure Digital Flip Video Ultra Camcorder
We have some videos we want to transfer to the computer. We are running Mac OSX with the Leopard software. When I attach the camera, I see the point and shoot icon for a short time and then I hear a beep and receive a pop up document screen that tells me I disconnected my item incorrectly and that I could lose data doing it. I cannot keep the point and shoot icon on the screen long enough to even open it and install the Mac software. Please help. Our model is older. It is the small white model from at least 2 years ago.
Put the batteries in the camera, then connect via the USB flip connection. The camera will show up on the desktop like a flash drive does. Open it when it shows up. Drill until you find the avi movies and drag them to your desktop. You may have to convert them to quicktime files. If you cannot use the software that came with the camera (it does work), you can import the sections into iMovie.
Jul 14, 2009 | Pure Digital Flip Video Ultra Camcorder
427 people viewed this tip
David Payne
David Payne
