Tip & How-To about Cell Phones
When a device falls into water/when you are drenched.
Water in an equipment.
It is quite common that often we have one of our hand held devices accidentely fall into water leaving us into a loss of data and money in a matter of seconds.
Water is a great enemy as it conducts with the impurities present , specially when the circuit is sensitive and highly intergrated.
what ought to be done immediately as you retrieve the device is to remove the power source- the battery. Now allow it to dry but we need to assist the process , make it clear off contacts so as no intercircuit shorts prevail.
But to make an attempt remove the covers and wash well with petrol the printed circuit board both sides making sure that the plastics or display does not come into contact. This is purely to remove all trapped moisture within the pin configurations. Now use a dryer( hair dryer) very mildly so as to take off trapped water inthe through holes of the double sided board.
Repeat the job after few hours ,use a soldering iron if there are signs of smoky lead ( traces of battery voltage in electrolysis)
If there is fumes coming on when soldering iron is touched on spots repeat till you are sure of a total dry PCB.
Use a tooth brush to clean the PCB so that all points are scrubbed well.
Finally the few seconds that water got in is critical as water conducts, the inter circuit short in the first few seconds can damage critical circuits.
So you must be really lucky to get the device back in action.
Cell Phones Logo
bosch dishwaser. starts and stops, it will say clean. leaves water in the bottom. we purchased a new pump and still not working? :( :(
All dishwashers leave a little water in the bottom. However, I suspect there's an appreciable amount in the machine. I'd suggest you lift out the filter and check the drain port.
Feb 11, 2015 | Bosch Dishwashers
Water pressure loss
The arms that spin can get small pieces of food stuck in the holes where the water comes out. The arms are held in by a large plastic screw that most times can be loosen by hand. Once out clean out the arms of any food and anything else that doesn't belong there. Also check the bottom of the washer where the water inlet is and make sure there is nothing blocking the water form getting back to the pump.
I hope this helps:)
Apr 20, 2010 | Danby 17 in. DDW1802W Designer Series...
low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
2,866 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
