Tip & How-To about Computers & Internet
How to block usb in registry
Type regedit in run box goto local mechine current controlset0 service usb sto change the value to 4 and restart the pc
Computers & Internet Logo
i cant see my external ******* my pc
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
how to disable usb mass storage in windows xp
you might also give a shot to products like uhook usb security, as registry information can be re-edited
Mar 17, 2010 | Microsoft Windows XP Professional for PC
not detected by the pc
Aug 14, 2011 | Samsung G2 Portable External HX-MU064DC/...
My PC do not see the hard when I plug him in
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Mar 04, 2011 | Transcend StoreJet 2,5" (6,5cm) M2 640GB...
optical drive not playing
This may not apply but it's worth a shot....
Click Start > Run
Type Regedit in the run box.
Open "HKEY LOCAL MACHINE > SYSTEM > CURRENT CONTROL SET > CONTROL > CLASS >
{4D36E965-E325-11CE-BFC1-08002BE10318}
Look for keys called "Upper Filters" and "Lower Filters" and delete any values inside those keys, then restart the machine.
Note: If using Vista, be sure to right-click Regedit in the program list and choose "Run as Administrator", otherwise it won't let you change the values of the key.
Hope this helps,
Techneck09
Jun 10, 2008 | Dell Dimension 4700 PC Desktop
99 people viewed this tip
David Payne
David Payne
