Tip & How-To about Computers & Internet
How to change your computer background
Find a picture u like on the internet or on facbook right click then click set as background DADA!
Computers & Internet Logo
how to change background desktop for acer aspire one(notebook)
I am assuming you have Microsoft Windows installed on this machine. To change the desktop background, right-click on the desktop and click either "Properties" or "Personalize". A window will pop up showing the current settings, including the current desktop background. To change it locate the picture you want to change it to, then click "apply". Go back to the desktop to confirm the change has been made.
If the picture you would like to use is on the internet, you can right-click on the picture and select "set as background".
Hope this helps!
May 21, 2011 | Acer Aspire One PC Notebook
how do i set laptop background image on my compaq 615?
This can be found in the Help and Support section of Windows on your laptop.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconRight click on your desktop-Select personalize. This will open a window that asks you to select your desktop background
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    getcontent.aspx?assetid=8456a207-d4c8-401d-8729-c5dda3f0e72c&documentset=en-us&prod=win700&market=usLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
Note
  • If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
Tip
  • To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
getcontent.aspx?assetid=7abb27d7-2989-4144-81e3-0a51f703885d&documentset=en-us&prod=win700&market=usThe Set as Desktop Background option
Apr 24, 2011 | Computers & Internet
how do install a windows desktop background.
I assume you wish to set a picture as your Desktop Background, I hope you know it's called wallpaper. There are few options, but the simplest way is open the picture, right-click and select "Set as Desktop Background", the settings will be updated within few seconds. You'll be able to see the new desktop background. If you are using Windows xp, right click anywhere on the desktop (empty area), select "Properties", click "Desktop" tab, there you'll see the available options to select your picture. Click "Browse", locate your picture which you wish to set as background image and select it. Now, click "Open", and make sure "stretch" is selected in the "Position" box, and then click "Apply", then "Ok".. You can also do the same from the "Control Panel's" Display settings, double-click the "Display" icon to access the settings.
In the same way, in windows vista and windows 7, right-click (blank area) on the desktop, select "Properties" and make the changes from the "Desktop Background" options.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 11, 2011 | ASUS Eee PC 2G Surf Notebook
How do I change the background of my Acer without downloading any kind of program?
Do you mean the desktop background picture? If so then right click any picture and select "Set as desktop background". Good luck.
Aug 24, 2010 | Acer Aspire One AOA150-1949 Laptop
139 people viewed this tip
David Payne
David Payne
