Tip & How-To about Toys
How to remove price tags on the packages of your toys for MOC collectors
These are some ways : you can do an old school way of removing it by slowly/gently removing the tag / use a hair dryer and set it on medium heat and directing it to the tag, then after awhile, remove the tag / use another tape to remove the tag and also on the sticky residue after removing the tag / apply small amounts of acetone or wipe out on the tag and gently remove it. Hope this helps out.
Toys Logo
i am 50 years old with long hair that dries frizzy so i have to straighten it, but i want to go short, what style would suit my frizzy prone hair please
I understand your hair type as mine is the same way. I would suggest shoulder length cut with long layers and a side swept bang. Frizzy hair will stay frizzy until you either put product in it or you use a big round brush when blow drying. My favorite time saver after washing my hair is to put a dime size portion of hair oil into your palms and rub together and then run your palms over the top layer of your hair. Blow hair dry. And here's the quick style part. Get a set of velcro hair rollers in the largest and medium size you can find. Use the largest rollers on the top part of the head and medium for bottom layers. Using the hair dryer blow the heat on the curlers for about 15 seconds each. Turn the dryer to a cool setting and blow across each curler again. Remove the curlers and brush out and style. Your hair will be smooth and have body. I use the curlers also on days i don't wash my hair. I just roll the top crown using about 3 rollers to get body on top. I have found the 2 inch rollers work well to give body without curl and also smooth the hair. This is so much faster than using a curling iron or flat iron all over.
Jan 30, 2015 | Health & Beauty
rainbow colors after screen gets wet
Use a hair dryer on gentle heat and dry it out slowly and evenly, keep it on and warm, don't allow it to cool down for a couple of days
Jul 15, 2014 | LG Televison & Video
replace fuse
I looked up your machine on repair clinic and it has a thermistor instead of a old school control T-stat. That might well be the problem.
Control might not have any idea what the temp is inside the drum or it could be off a hair. Not sure exactly how it works. The old school way without electronics was nice. This new stuff is crappy.
Feb 02, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Remove the logo from under-mount ceramic sink
I would say if you use heat use a heat gun. Better heat but be careful, they are much hotter than you think and you do not want to damage the finish.
Nov 21, 2013 | American Standard Home
dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
974 people viewed this tip
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
