Tip & How-To about Computers & Internet
How to Delete Windows administrator Password without any software
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I have done a research of losing Windows administrator password and find out more than 50% who have set password on their pc will finally forget it,espercially those women,add password to prevent their kids from downloading any games.
There are many reasons account for this.No mather how,when you realize you have forgotten password,you may try everthing you could do as there are many works waitting for you.No doubt, many ways can help you remove or recover the lost password, But here,I will show you how to delete Windows administrator password without any software.
Method 1
Boot up with DOS and delete the sam.exe and sam.log files from Windows\system32\config in your hard drive. Now when you boot up in NT the password on your built-in administrator account which will be blank (i.e No password). This solution works only if your hard drive is FAT kind.
Method 2
Step 1. Put your hard disk of your computer in any other pc .
Step 2. Boot that computer and use your hard disk as a secondary hard disk (D'nt boot as primary hard disk ).
Step 3. Then open that drive in which the victim's window(or your window) is installed.
Step 4. Go to location windows->system32->config
Step 5. And delete SAM.exe and SAM.log
Step 6. Now remove hard disk and put in your computer.
Step 7. And boot your computer
Method 3
Start system and press F8 key when Windows is starting up. Then select Safe Mode with Command Prompt and enter. Choose Administrator,the default password may be blank if you don't set the default administrator password before.Then you will enter into doc Command as following.
Type " net user net user xxx 12345 /add " (xxx is the locked accout name and 123456 is the new password set on this account).Then you will see the Command Completed Successfully.
Try these three method if you do not want to download a program to recover windows password. The preconditions is you should understand and be familiar with the operations
However,if you want to gain access to your pc in emergency,I still suggest you login to another PC which can link to internet and download a windows password recovery software to help.
Computers & Internet Logo
Have a MSI Wind Notebook and Forgot my Administrator password
At one time , I had the experience with forgetting Windows admin password. Finally I use Windows Password Reset .The program is easy to use.
Here I just list the simple steps:
Step 1: Download Windows Password Reset from http://www.windowspasswordreset.net
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting
Step 4: Reset Windows password
It's worth a try! Good luck~
Jul 30, 2012 | MSI Computers & Internet
wrong administrators password
Don't worry, The first thing whichyou check if you forget login password. When we install Windows, itautomatically creates an account "Administrator" and sets its password toblank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen /Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box.Now type "Administrator" (without quotes) in Username and leave Password fieldblank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "ControlPanel -> User Accounts".
Same thing can be done using Safe Mode. In Safe ModeWindows will show this in-built Administrator account in Login screen.
Or you can use the third party password reset software like Windows Password Recovery Basic
Nov 14, 2010 | Compaq NX6110 TFT XGA Notebook
forgot password
1. Start up into safe mode (press F8 at startup) 2. log in as 'administrator' 3. go into control panels, users, and clear the password on the account that you have a problem. 4. restart.
Aug 18, 2010 | Dell Studio 1535 Notebook
I forget administrator password in winxp
Goto safe mode there you wlll see the administrator account .login with administrator account and then goto control panel and then open 'user' .now select the user for which you want to change the password..
Aug 22, 2008 | Microsoft Windows XP Professional With...
I HAVE FORGOTTEN THE PASS WORD ON THE DESK TOP ACER COMPUTER
which password ru forget os password or bious password
Jul 09, 2008 | Acer Computers & Internet
88 people viewed this tip
David Payne
David Payne
