Tip & How-To about Dishwashers
How to make your undercounter dishwasher clean better.
Run the water at your sink until it is as hot as it will get and use liquid detergent. Many be you have your water heaters set at 120 degrees for saftey but that is to low for powered detergents.
Dishwashers Logo
detergent tablet will not dissolve?
Check water temp in might be to cool that is the first step......
Oct 06, 2014 | CDA WC430 Dishwasher
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
maytag quiet series 100 leaves residue and granules all over
are you using powder detergent or liquid. you may just need to switch the type of detergent you use. liquid in my opinion is better. also you may want to check the temperature of your hot water. ideal temp for proper washin is 120 degrees F. also if you run the hot water at the sink first before running the dishwasher, that will help you.
Oct 17, 2011 | Maytag Dishwasher
Dishwasher runs for 3 hours
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Aug 14, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
250 people viewed this tip
Top Dishwashers Experts
