Tip & How-To about Computers & Internet
How to make your external drive icon re-appear inside my computer icon
When your external drive does not appear in "my computer" in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer.
Computers & Internet Logo
not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
my hard drive is not being detected & the light is flashing on it as well
when your external drive is not being detected or does not appear in "my computer" in windows vista or windows 7. Try doing this option: just right click on my computer, click on manage, then go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer. Or you can restart your computer and check if it is detected.
Jan 03, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
my drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to lose...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
external drive not recognised by pc, do I need adriver update or is it more serious
Sep 27, 2010 | Western Digital My Book Essential 1TB...
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to NTFS to work with Windows Vista and if so, how is this done?
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Jul 17, 2008 | Toshiba Computers & Internet
171 people viewed this tip
David Payne
David Payne
