Tip & How-To about Video Game Consoles & Games
How to protect the thumbsticks on your xbox 360 controllers
Just use the the protective foams from your old earphones. If you want to take care and prevent the thumbsticks from breaking or chipping, just use the foams from your old earphones.
Video Game Consoles & Games Logo
How to take apart
Video is short sorry, so locate and remove the 5 screws on the back of ur controller. Push in the middle between the two thumbstick. U will feel it pop. Then go along the sides and carefully pry it open. Take ur time and pay attention to how things are inside. These controllers r a mess inside. To remove the rumble packs u must de-solder them. And to remove the board u need to locate the screw that is holding it in and remove it. DO NOT lose the small foam piece inside that goes under the sensor film. Without that ur controller will not work. GOOD LUCK AND GO ON YOUTUBE FOR A FULL VIDEO
Oct 18, 2012 | Video Game Consoles & Games
error code 5C00 what is this and how do you repair this erroe
This error is shown when there is any kind of foreign material or packing material stuck inside the printer which restricting the printhead to move freely. To resolve this issue, please follow the instructions mentioned below:
1) Confirm that the printer is powered off.
2) Disconnect the power cord from the printer or at the wall outlet or both.
3) Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray. If that is the case, please refer to the illustration in step 3 to ensure the white foam piece is removed along with the protective tape. skumar_sreen.gif
4) Pull the orange protective tape (A) and remove the white foam (protective material) (B). skumar_sreen.jpg
5) If the the white foam was not removed along with the orange protective tape, check for it on the right, inside the printer. a) With the printer powered off and unplugged, slide the print head carriage to the left. b) Looking inside the printer from the left, locate the white foam in front of the purge area. Note: It is recommended to use a thin latex glove as there may be ink mist on the white foam or surrounding print area. skumar_sreen_0.jpg
c) Cautiously remove the white foam with your hands. Be careful not to touch any other components in the printer.
6) After removing the packing material, look for and remove any other paper debris or foreign objects from the extreme left and right sides of the carriage area.
7) Close the scanning unit cover.
8) Reconnect the power cord and then power on the printer.
Aug 30, 2011 | Canon MP560 All-In-One InkJet Printer
the mirror damper on my Canon AV-1 has been deteriorating (smashed). Are those dampers truly essential to the camera's proper function?
Basically, yes. The function of this foam is to both prevent mirror slap and reduce vibration, as well as to protect the mirror. The foam is easy, and cheap to replace, mirrors are not. Spend the $5 for the foam and not the $100 for a broken mirror.
Aug 05, 2011 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
how do I open up the earphone to refasten the mounting screw
1. Carefully remove the ear pad.
2. There is a shiny plastic cover over the speaker with some foam padding. Gently pry this off - it is sticky.
3. You will now see the speaker holder - it is round and has 4 slots. If you gently rotate it anti clockwise it can be removed, releasing the speaker.
4. Under the speaker is a small round plastic sticker, this protects the back of the speaker from the screw - remove it.
5. You will now see the screw head - cross head screw - tighten it back onto the headpiece and re-assemble all components.
Apr 05, 2011 | Sony MDR-NC40 Consumer Headphones
My shure e4s have a larger nozzle than other e4s and scl4s I seen. This makes buying comply foam tips near impossible. Is there any chance my earphones could in fact been a variation of the e4s?
I think you have counterfeit E4 earphones. All genuine E4 earphones had the smaller nozzle. Also, on a genuine E4 earphone, the silver colored ring is metal and unscrews from the body of the earphone. If the silver colored ring on your earphones is plastic and does not unscrew, then they are counterfeit.
Sep 01, 2010 | Shure E4 Professional Headphones
986 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
