Tip & How-To about Computers & Internet
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
Computers & Internet Logo
dell error code 2000-0151 incorrect status 28
That error indicates an "incorrect status" of your optical drive. I suggest you run the Dell diagnostics on your drive. To test your CD/DVD drive from the utility partition:
1. Reboot your system. When you see the Dell logo, hit F12 to enter the boot menu.
2. Select Boot to utility partition.
3. Select Test System.
4. Select Custom Test.
5. Use the arrow keys or mouse to select your CD/DVD drive.
6. Insert a CD or DVD.
7. Click Run Tests.
8. Write down any error messages.
Feb 28, 2014 | Dell OptiPlex 390 DT Desktop Computer...
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format it.Despite pressing key F1.F2,del,esc,ctrl+atl+esc but no use.there is no booting.pl advise.
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
my acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
xp instal
HOW TO INSTALL FROM CD SIMPLIFIED.
be sure to have 16 character product key handy
1.be sure bios is set to boot from cd (see your boot screen for prompt to enter setup.)
2.insert cd and reboot you should be prompted to "hit any key to boot from cd"
3.hit any key
4.follow prompts if you have any third party raid drivers hit f6 when prompted.
5.install should take about 40 minutes depending on computer speed don't forget to update immediately after reinstall
to reinstall from harddive partition follow prompts on boot screen or look for recovery software on your programs menu..
Apr 23, 2009 | Computers & Internet
i cannot access any files on my lap top..they are all closed...how do i reformat
put your Windows cd in and reboot. During the start up hit the f12 key and go to the boot menu. Select boot from cd and you will be able to reinstall windows.
Nov 03, 2008 | Computers & Internet
151 people viewed this tip
David Payne
David Payne
