Tip & How-To about Computers & Internet
Mac Laptap
Reminder to all mac laptop user,upon charging your laptop before or after you finished charging make sure not to twist the cable of your charger because as the plastic material use in cable wire deform and caused short circuit to your charger,this is common to mac laptop charger
Computers & Internet Logo
can't unlock admnistrator macbook pro i7 4GB RAM
Boot into Single User Mode and remove a setup file
  • Restart the Mac holding down the Command+S keys, this will take you into Single User Mode and it's Terminal interface
  • You'll need to check the filesystem first:
  • fsck -fy
  • Next, you must mount the root drive as writeable so that changes will save:
  • mount -uw /
  • Now, type the following command exactly, followed by the enter key:
  • rm /var/db/.applesetupdone
  • After removing the applesetupdone file, you need to reboot, type 'reboot' and hit enter
Stage 2) Create a New User Account upon System Boot
You aren't finished, but the hard part is now over - no more command lines, you'll now be in the familiar Mac OS X GUI to finish the password reset process. In this step we just create a new user account as if you just got a new Mac:
  • Upon reboot, you will be presented with the traditional "Welcome Wizard" startup screen just like when you first get a Mac
  • Follow the welcome wizard and create a new user account - making the account name different from the account whose password you want to recover
  • Continue on and boot into Mac OS X with this newly created user account, this new user account is an Administrator and has administrative access
Stage 3) Reset the Forgot Password via System Preferences
You are almost done, now you just need to reset the forgotten user account password using the Accounts control panel:
  • Once you are booted into Mac OS X, click on the Apple logo and then navigate down to "System Preferences"
  • Click on the "Accounts" icon in System Preferences
  • Click on the Lock icon in the lower left corner of the "Accounts" preference window and enter the newly created user credentials, this enables you to change other user accounts and reset other users passwords
  • On the left side user panel, select the user account containing the forgotten password
  • With the user of the forgotten password account selected, click on the "Reset Password" button
  • Enter a new password for that user, be sure to include a meaningful hint so you don't forget it again!
  • Close System Preferences and reboot the Mac
  • You can now login to the previously inaccessible user account using the newly reset password! All user files and settings are maintained as before the password was forgotten
Optional: If you'd like, you can delete the temporary account you created to reset the users password. This is wise for security purposes.
Nov 08, 2013 | Apple 17" MacBook Pro Intel Core i7...
laptop computer will not charge
2 things either battery to be change
or charger it self
or check pin and cable of charger
Jan 12, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The light on my charger does not come on.
If there is no damage to the socket on your notebook, you will need a new charger. No quick fix unfortunately
Sep 09, 2010 | Apple MacBook Pro Notebook
Hi in my blackberry pearl appear a battery with a red line in the screen and it does not function
it probably means that your charger isn't charging your phone fully. you need to consider getting a new battery and charger.
Oct 15, 2009 | Cell Phones
Compaq presario v2000 wont charge
It has happened to me as well since i have the exact same model laptop. The problem is a loose cable or the wire inside is damaged. I just bought a new charger since buying one is cheaper than taking the risks that the repair might cause a short after using it for some time.
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
244 people viewed this tip
David Payne
David Payne
