Tip & How-To about Computers & Internet
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
Computers & Internet Logo
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
Aug 08, 2014 | Acer TravelMate Computers & Internet
When I work on my laptop it suddenly shut down, blue screen, many written things, and
This sounds like a BSOD (Blue Screen of Death). Check for that in Google. Image at www.bsod.org.
Did that happen once or is it more frequent?
It could be heat, blow out the dust bunnies with compressed air.
If it is infrequent, it is a part of the price of using Windows.
If it is more frequent, try to see what the failures have in common. If you are always using the same program when it happens, see if there is an upgrade for the program.
More information will be necessary to solve this.
Aug 22, 2012 | Genuine DELL 250w SFF Power Supply For the...
Screen shutting down
Well, Gestion Alim is French for "Power Management." It means that your computer is shutting off power to the video using the ACPI power settings, probably stand-by or hibernation. Bring up the Power Management settings in your operating system (in Windows, it's the Display icon in the Control Panel) and change them to something more reasonable. If you want to disable them completely in Windows, change to "Presentation" and make sure that hard disks and display are both set to "Never" shut-off.
Nov 08, 2007 | LG Flatron L1750S 17" LCD Monitor
Startup problem
This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
604 people viewed this tip
David Payne
David Payne
