Tip & How-To about Computers & Internet
How to Reset Windows Server 2008 R2 Password When you have lost it
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Besides Windows 7.Windows Server 2008 R2 Operating Systems are the latest and more secured versions from Microsoft.
Windows Server 2008 R2 is a server operating system produced by Microsoft. It was released to manufacturing on July 22, 2009, launched on October 22, 2009. According to the Windows Server Team blog, the retail availability was September 14, 2009. It is built on Windows NT 6.1, the same core operating system used with the end-user oriented Windows 7. It is the first 64-bit only operating system release from Microsoft. Windows Server 2008 R2 is an updated operating system to Windows Server 2008.
For reseting Windows Server 2008 R2 password,I have used several methods,and this method is very easy and 100% worked on 2008 R2 servers. This is very quick, because it clears the administrator password straightaway. There are some products available to find out admin password, which takes lot of time to find.
Windows Password Key is the product you required to reset admin password.This is not free,you must pay $19.95 .But you can get it freely somewhere,You can free download from Lost Windows Password website.
How to reset Windows Server 2008 R2 password with Windows Password Key
Step 1. Burn a CD/DVD or USB Drive to reset Vista password.
Download Windows Password Key and install in a computer. And follow the step-by-step guide to burn a CD/DVD or USB drive to reset password.
Step 2: Set BIOS to boot from CD ROM or USB.
Insert the burned CD/DVD or USB drive in the computer you want to reset password, and then change the BIOS settings of the computer as follows:
1st. Start computer and press F2 or Delete to enter BISO setup during the initial startup screen.
Note: What key is pressed depends on the manufacturers, but in most cases it is F2 or Delete.
2nd. Use the arrow keys to select the Boot tab, and then select Boot Device Priority and press Enter.
3rd. Choose first boot device to CDROM or USB flash drive, and then press F10 to save settings. The computer will restart with the changed settings automatically.
Note: When you want to boot from USB, you should adjust USB to 1st Drive by entering Hard Disk Drives firstly before selecting first boot device to USB flash drive.
Step 3: Remove the forgotten Windows password under DOS.
1st. Choose the installation path of Windows, and enter the ID of the path
2nd. All the user names will be displayed for you. You can select one to remove its password by entering the ID of the User Name.
3rd. Enter y to confirm and continue, enter n to return to previous menu.
4th. After removing the password for the selected user name, you can enter y to continue to reset
passwords of other user names, or enter n to restart computer. And now you can log on computer without password.
We did. It's very simple and finished in less than two minutes.
Now you can regain access your operating system and create a new administrator password. The best thing of using this method is that you shouldn't lose any data on your computer. Furthermore, If you can't find a computer which has a CD/DVD writer or the locked computer have no a CD-ROM, You can burn the ISO image file into a USB flash drive and use the USB flash drive to recover your Windows administrator password.
Try these three methods the next time you have lost Windows administrator password, which you do not need to reinstall Windows system for getting back to Windows by removing lost or forgotten password.
Computers & Internet Logo
how to use the rupees symbol in logitech k200 keyboard
you may download Rupee.rtf file from internet..Place it in Start> Control Panel > Fonts....When u open an editor like MS Word...for rupee symbol select "Rupee" from font drop-down and for typing it use the key just above the tab key on ur keyboard. You are done.
Nov 16, 2011 | Logitech 967437-0403 Keyboard
i'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
Dec 31, 2010 | Computers & Internet
147 people viewed this tip
David Payne
David Payne
