Tip & How-To about Computers & Internet
Computer turns ON but there is no display?
Drain it! You might be surprised that one day as you turn your computer on, it shows no display. It can be caused by electrical charges on the motherboard, I do not specifically know how it affects the display but in case this happens to you try to do a Power Drain. It's easy, first, take the battery out from the laptop and unplug the AC Adapter if it is connected(for desktops, unplug power cord from the CPU/tower) then press and hold the power button down for at least 30 seconds. plug power supply back into your system and turn it back on. There goes your display once again.
Computers & Internet Logo
laptop screen not coming on
>It's easy, first, press the power button for about 5 seconds (if the indicator light for power is still lit)
>Take the battery out from the laptop
>Unplug the AC Adapter if it is connected(for desktops, unplug power cord from the CPU/tower)
>Then press and hold the power button down for at least 30 seconds.
>Plug power supply back into your system
>Turn it back on.
Thank you for choosing FixYa! have a great day!
Apr 04, 2011 | Acer Aspire 5742Z-4200 Notebook
i have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Washing machine turns off and it shows f20 on display
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F20 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F20 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump. (You will need to remove the front lower panel to access the pump and filter)
• If the above does not correct the problem replace the pump.
Jan 17, 2010 | Kenmore Washing Machines
Whirlpool Front load won't drain showing a F 02 Code
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Oct 08, 2009 | Whirlpool GHW9100L Front Load Washer
1,975 people viewed this tip
David Payne
David Payne
