Tip & How-To about Rio Carbon MP3 Player
Wipe and reboot Rio carbon
Many problems have been found with the Rio carbon and although it is a good media player I think most people will have some problems with it.
Many of these problems can be solved by wiping and rebooting your player:
This may fix the upgrader message but if not the try replacing your hard drive (see: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon)
Windows only... Sorry but I am not familiar with the way to do it with a mac or linux pc...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=215).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Rio Carbon MP3 Player Logo
How do I access the EQ section on my Rio Carbon Pearl 5 gig to change the equalizer settings?
i found the following solution:
1 Press MENU.
2 Select Settings.
3 Select Equalizer.
For more specific information follow the following link, its a manual. It answers you question on page 31.
http://www.rioaudio.com/support/rio/downloads/Carbon/RioCarbonPlaysForSure.pdf
Good luck
Dec 21, 2008 | Rio Carbon MP3 Player
More info needed on CF card for Rio Carbon
I have sent some more details for you.
Please tell me if you don't get them.
Mowcius
Jun 16, 2008 | Rio Carbon MP3 Player
rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
broke volume dial
http://www.content-type.com/1461305906/carbon+3.04.EXE.htm This link takes you to a site which will allow you to download an upgrade to your carbon's software which includes a volume option in the settings menu. My wheel broke a while ago too, and I bought a new player before I found this link. I still think this is the most compact and portable 5gb player on the market. I'm back to using it now.
Aug 21, 2006 | Rio Carbon MP3 Player
Rio Carbon Repair
I think you should keep looking for another solution, but what i know is that for out of warranty carbon players you can't get it fixed through rio/sonic blue, they will only replace it for a new one/remanufactured one for 99$. Here's a link to a previous post of someone who had the same problem as you: http://www.fixya.com/ThreadView.aspx?thid=101466&prdid=230965 Good luck
Mar 06, 2006 | Rio Carbon MP3 Player
1,042 people viewed this tip
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
