Replacing Water Inlet Valve on Kenmore & Whirlpool washers
By
jsrock516
Rank: Guru
Rating: 96%, 6472 votes
posted on May 16, 2008
This
advice is for Kenmore & Whirlpool model TOP LOADING washing machines. If you suspect you have a defective Water
Inlet valve (also known as a FILL valve or MIXING valve) it can easily be
diagnosed by performing the following steps:
First, make sure the water taps are turned on all the way, and the fill hoses
are not kinked in anyway. If everything
checks okay, proceed to the next step.
Now, turn the water taps off, disconnect the fill hoses from the back of the
washer and place them in the wash tub.
Turn the taps back on and make sure you have proper and forceful water
flow (minimum water pressure should be 10-25PSI).
Check the sediment screens on the Water Inlet valve on the back of the
washer. Sometimes these screens will
clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works
well.
If
you’ve attempted all the steps above, but still have no luck, more than likely
the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE
attempting. This is a simple repair that
any “Do-It-Yourselfer” can accomplish. Follow
the steps provided:
1.
Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on
which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the
top from the back of the washer. The cap will pull off towards you as you are
facing the unit from the front of the washer. There will be a screw under each
end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a
putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the
back of the washer in its resting position. Use care not to stress the small
plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat
blade screwdriver and place it in the groove of the clip on the washer top.
With the screwdriver firmly in the groove, push away from you towards the back
of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on
the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip
under the front rim of the washer opening. Do not grab the wash tub, just the
casing. Tilt the washer case from the back first towards you, slide forward
slightly, and then lift up. The entire case comes off exposing the wash tub and
components.
7. The inlet valve is located on the back panel with two or more sets of electrical
connectors attached to it. The connectors are
usually color-coded to indicate which valve is HOT and which valve is
COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check
the contacts for corrosion. Sometimes a
good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of
pliers to release the hose clamps.
Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed,
loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you
correctly connect the HOT & COLD electrical connections (RED is usually the
HOT water side). Make sure all hoses are
fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case
under front rim and place it on the washer frame. While looking down through
the washer lid opening, make sure the front lip of the case is placed UNDER the
washer frame and rocked back onto the frame to ensure that the small cleats on
the frame fit into the slotted grooves on the washer case base. If you do not
get the case seated correctly it will rattle and vibrate while the washer is in
operation.
12. Make the back of the washer fits into the washer casing on each side and
reinsert the brass clips. Place the clip into the slot on the back of the
washer first, and then forcefully push it into the opening on top of the
washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not
reconnect it, the washer will not work correctly.
14. Reinstall console.
I hope these instructions are found to be helpful. If anyone has any questions please go to my
profile at: http://www.fixya.com/users/jsrock516 and use the “ASK ME” feature. This will ensure your concerns are answered
much faster.
Was this helpful?22 people thought this was helpful
Comment #1
posted on Sep 11, 2009
By
vv19
Rank: Apprentice
Rating: 0%, 0 votes
This advice was right on the mark. My problem was simply a clogged inlet screen. Thank you very much!!! I can only imagine how much I saved, as I may have been forced to by a new inlet valve I really didn't need if I had called an appliance repair outfit. Great Site!
Comment #2
posted on Jun 10, 2009
By
Veebeen
Rank: Apprentice
Rating: 0%, 0 votes
Fantastic advice. My husband and I just replaced our intake valve and our washer is washing like a champ. Your directions were easy to follow and 100% accurate.
Many thanks!
Can you Help with these Washing Machines problems?
Kenmore 22422 Top Load Washer
Washer runs for 10 seconds then stops for 5 - 15 minutes.
after washing cycle there are balls of lint over...
Foul water smell from the washer, occassionally clothes...
The washer stopped on the drain/spin cycle, with the water...
will not agitate
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
(800) 357-1234
Welcome to Action Appliance Repair. We have...
