Tip & How-To about Computers & Internet
Laptop computer will not shut down
Disengage the battery completely from the laptop
Computers & Internet Logo
car doesn't start
Have the Voltage in the Battery checked. The antitheft system will sometimes disengage the starter if the battery is below Specs.
If you disconnect the battery completely on the Honda and then jump the Honda with another battery, it will verify the battery in the Honda is the problem.
May 30, 2012 | Honda Accord Cars & Trucks
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
I just installed a new battery in my 2000 Mercury Cougar and as soon as I attached the second battery cable the car alarm went off and the two blinker arrows on the dash are blinking. If I start the car, the alarm goes off in a minute or two. How do I disengage the alarm? Pat M.
You can disengage alarm with a remote if you have one otherwise, close bonnet, all doors and lock the car by turning key completely to the left and right few times and do the same to unlock. This will dead lock and unlock the car. When you hookup the battery make sure you connect red wire first and then the black one.
Jan 16, 2011 | 2000 Mercury Cougar
I am not getting any power to the laptop i have the battery disengage from the laptop with direct power it is still not comming on
you need to put the baterry back on if the battery is bad replace it, the charger is for the baterry. a laptop needs a battery to work, the power that is coming out of the charger only charges the battery it isnt going to power on the pc, it is for maintaning the proper voltage in the battery.
Jun 03, 2010 | E-Machines M2105 Notebook
I have a dell laptop and I'm not sure how to disconect it from the external battery
To remove the battery, flip the unit over and push the battery release latch to disengage the battery.
The reserve battery is located in a compartment within the battery bay. To replace a reserve battery, first open the reserve battery door:
Pull the reserve battery out of its compartment, and disconnect the cable from the connector.
Oct 03, 2009 | Dell Latitude D600 Notebook
192 people viewed this tip
David Payne
David Payne
