Tip & How-To about Computers & Internet
How to completely uninstall a software
How to remove leftover files,folders and registry keys after uninstalling a software:
OK, first lets see what actually happens when we install a software?
When we install a software it copies some of its files usually in C:\Program Files , C:\Windows\System32 , Registry.
If we uninstall a Software from Add/Remove Program ( Win+R --> appwiz.cpl), it removes some files from C:\program Files only.
It will not remove the softwares supporting files and folders from System32 or Registry.
Now lets see how to remove these leftover files:
I use a small freeware utility called Revounistaller for this process.
What is Revounistaller ?
Revo Uninstaller helps you to uninstall and remove unwanted programs installed on your computer even if you have problems uninstalling and cannot uninstall them from "Windows Add or Remove Programs" control panel applet. Revo Uninstaller is a much faster and more powerful alternative to "Windows Add or Remove Programs" applet! With its advanced and fast algorithm, Revo Uninstaller analyzes an application's data before uninstall and scans after you uninstall an application. After the program's regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer. Even if you have a broken installation, Revo Uninstaller scans for an application's data on your hard disk drives and in the Windows registry and shows all found files, folders and registry keys so you can delete them.
With its unique "Hunter mode", Revo Uninstaller offers you some simple, easy to use, but effective and powerful approaches to manage (uninstall, stop, delete, disable from auto starting) and to get information about your installed and/or running programs.
You can download revo through : http://tinyurl.com/22scp8r
Computers & Internet Logo
How do I uninstall unwanted downloads
Use the uninstall option in the control panel.
Jan 10, 2016 | Computers & Internet
I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting a pop-up message that says "Cannot determine configuration." I tried to uninstall the program so I could reinstall it from the discs again, but my computer won't let me uninstall it now! Can you please help me???
Hi.
If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
Download Latest Version of CCleaner
If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
invalid at all.
There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
Hope this helps.
Regards.
Jun 02, 2011 | Broderbund American Greetings Creatacard...
I uninstalled Fix8 now my webcam keeps comming up with use Fix8 when i can't and i dont wish to install it again
Try using Revo Uninstaller to search for leftover files from the Fix8 install. http://www.revouninstaller.com
Once you install the software, try doing a "Forced Uninstall" to remove any leftover files/registry keys from the Fix8 program.
Mar 02, 2011 | Computers & Internet
unresponding firefox 3.0.8
Goto add/remove program then select it there to uninstall. Or uninstall that in installed folder in the programs file select its uninstall.
Another is install it once again or select repair. Then uninstall it .
Or better use a third party software that could also totally uninstalled files and registry key leftover whenever you try to uninstall a program.
Apr 11, 2009 | Computers & Internet
227 people viewed this tip
David Payne
David Payne
