Tip & How-To about Sewing Machines
Manuals
Most machines are pretty similar in terms of threading, so try you tube for instruction.
Sewing Machines Logo
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
Jul 30, 2017 | Sewing Machines
How to thread a empisal mercury 404 overlocker
This may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwib-vjWo4HPAhUS5mMKHQqFBJ4QFghHMAc&url=http%3A%2F%2Fwww.empisal.co.za%2Fwp-content%2Fuploads%2F2016%2F02%2FEOL-4D-Instruction-Manual.pdf&usg=AFQjCNEyQGCGMvjXwTjOR8JHacxAL1WHJg&cad=rja
It may not be the same model, but similar machines pretty much thread the same way. FWIW, always RAISE the PRESSER FOOT when threading. This releases the tension disk and allows the thread to seat firmly. When pulling thread through the tension disk, give each an extra little tug to confirm it is seated.
Also, if there is particular order which thread to thread first, follow the instructions every time or your machine may not work. Overlockers are finicky. Also, if a thread breaks, it is usually better to remove all the threads and rethread from the beginning. Trying to fish a thread through out of order will generally end in failure. In this manual, the pink (upper looper) thread is threaded first, then the yellow (lower looper) is second, then the needles.
Sep 08, 2016 | Sewing Machines
How do I thread the bobbin of my Singer Seduction 6250 sewing machine?
Go to you tube singer may have some videos for this machine or it is probably similar to most other machines or you can just call they are pretty nice folks at singer customer service
Oct 20, 2014 | Sewing Machines
How to thread machine
try this
on your browser search bar type in---user manual for pacesetter vx2051 sewing machine--- and see if there is a web page with a pdf version down load
Jan 20, 2018 | Brother Sewing Machines
1,228 people viewed this tip
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
